7 members (Charles in CA, 32Fordpuchoptop, tclederman, 68ironhead, JW51, Shade Baby, 3B),
102
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,648 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 87 'Bolter | | 'Bolter Joined: Feb 2019 Posts: 87 | I have the trans dropped in my truck currently to replace the ring gear. It's a 69 C60 with an dana 5756-B 5 speed with a 427. There was 2 hot spots on the flywheel and the clutch has seen better days so I went ahead and had the flywheel resurfaced, they took .005" off and I have a .005" shim for it. I also ordered this clutch from rock auto (the organic one) https://www.rockauto.com/en/catalog/...lutch+kit,1993now I'm sure some of you are laughing at my inexperience. Obviously it's not the correct one. Where is a go to place for clutches for these trucks? The only ones I've found is $900 and that seems a bit much this one https://fortwayneclutch.com/product/...sku-mu1266_kt/ What options do I have with the current one? Is $900 a good deal? I just want to be able to turn the key and start the engine for the first time since I've owned the truck already!!! Any help is appreciated. | | | | | Joined: Feb 2016 Posts: 1,983 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,983 | I used the dimensions of the clutch diameter, spline count and diameter, and Borg & Beck type pressure plate and was able to match it. Mine is not a big block and 12 years older than yours but you should be able to find a clutch to fit.
| | | | | Joined: May 2017 Posts: 330 'Bolter | | 'Bolter Joined: May 2017 Posts: 330 | Any local truck repair place should be able to steer you to a local source. Like buckshot said above, get the disc diameter, the spline count and dimensions, lever style or diaphragm pressure plate and the height of the clutch arms/diaphragm fingers. I would bring all the parts along when shopping. A big auto parts store could likely fix you up too.
Mac :{)
1962 K10 short step side, much modified for rally 1969 T50 fire truck, almost nos, needs a few things
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Pvmt-Pndr, my F.L.A.P.S. can provide a complete 13" clutch kit in either diaphragm or Borg and Beck four lever style for $575.00 Canadian, so you should be able to find a clutch kit for that amount or probably less in American funds, hope that helps. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | American Power Brake and Clutch in Dallas resurfaced the flywheel, rebuilt the PP, and relined the clutch plate for my 1941 Ross forklift For about $300 (8 years ago). New parts were impossible to find for a machine that was used by the military in WW2.
Evan
| | | | | Joined: Feb 2019 Posts: 87 'Bolter | | 'Bolter Joined: Feb 2019 Posts: 87 | It turns out the clutch that I have hasn't been made in 30 years or so. Something about the 4 bolt pattern. None the less I found a place in Detroit called Detroit clutch masters who said they can rebuild it for me. I shipped it this morning. A rough estimate of around $200. The clutch I'm sure has quite a bit of life left in it but I do not want to have a reason to pull the trans again if I don't have to. It wasn't a bad job to be honest but since I had the flywheel resurfaced I may as well have the clutch gone through also. Do it once and do it right and roughly $200 vs $900 for the link I posted I'm not going to complain. | | |
