13 members (klhansen, Otto Skorzeny, Jims46, manymiles, MikeE, Southerntruck, joe apple, Hawkman, J Lucas, D B Cooper, Oldcaliforniakid, 2 invisible), 103 guests, and 2 robots.
Topics128,049
Posts1,055,674
#1310958 05/16/2019 10:42 PM
I have the trans dropped in my truck currently to replace the ring gear. It's a 69 C60 with an dana 5756-B 5 speed with a 427. There was 2 hot spots on the flywheel and the clutch has seen better days so I went ahead and had the flywheel resurfaced, they took .005" off and I have a .005" shim for it. I also ordered this clutch from rock auto (the organic one) https://www.rockauto.com/en/catalog/...lutch+kit,1993now I'm sure some of you are laughing at my inexperience. Obviously it's not the correct one. Where is a go to place for clutches for these trucks? The only ones I've found is $900 and that seems a bit much this one https://fortwayneclutch.com/product/...sku-mu1266_kt/ What options do I have with the current one? Is $900 a good deal? I just want to be able to turn the key and start the engine for the first time since I've owned the truck already!!! Any help is appreciated.
Pvmt-Pndr #1310965 05/16/2019 11:17 PM
7
7 Offline
I used the dimensions of the clutch diameter, spline count and diameter, and Borg & Beck type pressure plate and was able to match it. Mine is not a big block and 12 years older than yours but you should be able to find a clutch to fit.
Pvmt-Pndr #1310972 05/17/2019 12:13 AM
Any local truck repair place should be able to steer you to a local source. Like buckshot said above, get the disc diameter, the spline count and dimensions, lever style or diaphragm pressure plate and the height of the clutch arms/diaphragm fingers. I would bring all the parts along when shopping. A big auto parts store could likely fix you up too.
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
Pvmt-Pndr #1311001 05/17/2019 2:20 PM
3B Offline
Hy Pvmt-Pndr, my F.L.A.P.S. can provide a complete 13" clutch kit in either diaphragm or Borg and Beck four lever style for $575.00 Canadian, so you should be able to find a clutch kit for that amount or probably less in American funds, hope that helps.
Pvmt-Pndr #1311161 05/19/2019 4:48 PM
American Power Brake and Clutch in Dallas resurfaced the flywheel, rebuilt the PP, and relined the clutch plate for my 1941 Ross forklift For about $300 (8 years ago). New parts were impossible to find for a machine that was used by the military in WW2.
Evan
Pvmt-Pndr #1311272 05/20/2019 3:52 PM
It turns out the clutch that I have hasn't been made in 30 years or so. Something about the 4 bolt pattern. None the less I found a place in Detroit called Detroit clutch masters who said they can rebuild it for me. I shipped it this morning. A rough estimate of around $200. The clutch I'm sure has quite a bit of life left in it but I do not want to have a reason to pull the trans again if I don't have to. It wasn't a bad job to be honest but since I had the flywheel resurfaced I may as well have the clutch gone through also. Do it once and do it right and roughly $200 vs $900 for the link I posted I'm not going to complain.
