0 members (), 162 guests, and 4 robots.
Topics128,089
Posts1,056,139
Members48,435
#1311072 05/18/2019 5:26 PM
This is my best guess as for appropriate forum for this question
I’m going to be replacing the intake (to offenhauser and need to plumb water heat) and exhaust manifold (Williams) soon and a power steering upgrade when kit arrives.
I got a belly (sadly the reason for power steering as I need a smaller wheel) which adds to challenge of reaching in over vendors.
Background for question done:
Q1: For those who have did manifold replacement w/ engine in, did you remove front clip?
Q2: if You didn’t, did you wish you did?
Q3: if you did, do you wish you didn’t
Note: I plan on leaving hood on.
I know I should just wait to do all at once
Any thoughts will be greatly appreciated
1954 Std Cab 3100 w/ 2 spare Engines
IL
1954 three window 3100
Q1: no
Q2: no
Q3: no
I might not correctly understand what you are doing.
“I know I should just wait to do all at once”
What should you do all at once?
Well having a belly can be meant to mean two different extremes. If you cannot reach the manifold bolts leaning over the fenders then you do need to remove the fenders if you are already standing on a stool.
Otherwise, like Tim says, no,no,no to your questions.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Riding in the Passing Lane
I think that belly would be more in the way removing the front clip then the manifold.
I have bad knees & shoulder. I usually jack the back end of the truck up high to help reach things under the hood.
George
1972 Chevy c10 Cheyenne Super
Absolutely not. Just opening a big can of worms.
I use my engine hoist to reach over the fenders into the engine compartment and lift out heavy parts such as manifold or head.
1951 Chevy Panel Truck
Plenty of room in there.
Thanks for input - I can’t remember were I heard the suggestion... kinda why I asked,
I got the info I was looking for
IL
Fox Offline
That’s what apprentices are for!
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
