1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#1310821 05/15/2019 4:30 PM
1951 Chevy 3100 3 speed column and 216 motor.
Clutch pedal grabs very high which makes it difficult to get goin without accelerating a lot. Would a clutch pedal adjustment fix that?
Bdron #1310837 05/15/2019 6:37 PM
You should have 3/4" to 1" free play at the top of the pedal travel before you feel the resistance of the pressure plate spring. That also prevents the throwout bearing from running all the time and wearing itself out. Clutch adjustment should be done at least as often as brakes, or maybe a little more frequently.
Got it. I’ll check it out and adjust it. Thanks for the help Jerry
