| | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2019 Posts: 23 New Guy | | New Guy Joined: May 2019 Posts: 23 | 1951 Chevy 3100 3 speed column and 216 motor.
Clutch pedal grabs very high which makes it difficult to get goin without accelerating a lot. Would a clutch pedal adjustment fix that? | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | You should have 3/4" to 1" free play at the top of the pedal travel before you feel the resistance of the pressure plate spring. That also prevents the throwout bearing from running all the time and wearing itself out. Clutch adjustment should be done at least as often as brakes, or maybe a little more frequently. Jerry
| | | | | Joined: May 2019 Posts: 23 New Guy | | New Guy Joined: May 2019 Posts: 23 | Got it. I’ll check it out and adjust it. Thanks for the help Jerry | | |
