2 members (Wooley, Hotrod Lincoln), 81 guests, and 3 robots.
Topics128,096
Posts1,056,488
Members48,444
I need new head bolts for my 261
I have looked everywhere, to no avail..... Help !!!!
Whatever you are doing, have a good time at it..... Ya gotta do it anyway... So, enjoy life !!!!
H Online: Content
Measure the length of the head bolts you need and go to either the Dorman or Pioneer open stock head bolt listings. They're simply 1/2"-13 Grade 8 head bolts, nothing fancy about them. You might consider using Grade 8 SAE flat washers under the bolt heads. Bolts for a 54-62 235 will work, also.
1 Offline
Are they the same as 235 216 head bolts? I have many of them.
Trombones Totem Poles And Old Trucks!
Place a Parts Wanted Ad in the Swap Meet?
' Offline
Dans GM Obsolete
Chinook , Montana
phone : 406 - 357 - 2615
Dan's has
( 19 ) SHORT head bolts - GM # 3835812
( 11 ) LONG head bolts - GM # 3835811
These are GM NOS Bolts .
They are getting very scarce to find in NOS .
PICS
Short Head Bolts - you will need ( 10 )
https://i.postimg.cc/W1yfjBw8/GM-NOS-Head-Bolts-2.jpg
https://i.postimg.cc/qBGC1T3b/Head-Bolts-GM-NOS.jpg
https://i.postimg.cc/37QmQLnr/GM-NOS-Head-Bolts-3835744.jpg
Long Head Bolts - You will need ( 8 )
https://i.postimg.cc/LsZQsxyp/Head-Bolts-12-GM-NOS-3835812.jpg
https://i.postimg.cc/nL49DbYt/3835743-Long-Head-Bolts.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Hallelujah !!!!! WONDERFUL !!! Talked to them.... Made my day !!!!! THANK you, George.....
Thanks again,
Carl
Hey George,
I have a set of head to block dowels coming... where do they go ?
I want to get this right...
Carl
' Offline
Carl ,
The two cylinder guide pins get screwed into the cylinder block
Front & Rear holes on the manifold side of the engine .
This holds the gasket in position so you can guide the cylinder head into place .
You can do a trial fit when the block & head are super clean .
Screw the guides thru the head gasket .
You could go to the hardware store & buy a couple of carriage bolts - 1/2 " - 13 x 5 or 6 inches
and cut the heads off to use as guides .
PIC
https://i.postimg.cc/FsPJfZVH/261-head.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
24601
Carl -- I removed your phone number from your post -- that sort of Personally Identifiable Information is best left to PM's or email.
And by the way, have you read our Tech Tip on 261 rebuilding?
Thanks for using our site!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Thanks John
Thank you....
