9 members (Otto Skorzeny, Gdads51, Paul Mullen, DavidBraley, TUTS 59, Ponchogl, Shaffer's1950, JoergK., mk72), 118 guests, and 4 robots.
Topics128,184
Posts1,057,196
Members48,465
Page 1 of 2 1 2
Hello All,
As you are all aware, the older rims and tires can be problematic to service or disassemble after being in use for 80 years... My solution to the issue was to have a new rim made to take care of the problem... I have found a company in California that will produce a rim similar to a Dodge Power Wagon for $ 245.00, but without any holes, and much like the rare 10.5 x 16 rim fitted to Canadian trucks sold for export...
The 10.5 x 16 rim might require modifying the fenders up front for the wider tires, but, I am willing to compromise and go with a narrower wheel up front 8" or 9" and not have to widen the fender by 4.75" and yet still have a wider tire fitted.. Another option would be to have staggered wheels... 8" up front and 10" in the rear. Opinions/information welcomed regarding suitable tires as well....Thank you.
Philippe Jeanneau
Crusing in the Passing Lane
What is your wheel bolt pattern on your truck?
Ed
10 x 7.25 with a 4 -3/4 center bore...
Philippe Jeanneau
Late '50's 22.5 tubeless wheels will fit with a hub spacer, easily made. Fit 9 x 22.5 tires well. Somewhat hard to find, look on farm trucks. A gentleman in Az had some modern 22.5's with that kind of centers made by some wheel CO.
Ed
Hello Ed, thank you for the suggestion... It would be interesting to see details and photos from this gentleman in AZ. For now it seems easier for me to have new wider wheels made for my truck since I want to convert it to a Long Range Desert Patrol configuration...
Philippe Jeanneau
He has a blue AD truck with black wood bed sides, look in old WOT or last couple years of Show Time.
Ed
Finally making some headway with the new wheel set-up... Backspaces for both front and rear are sorted and the new rubber has finally arrived also!
Philippe Jeanneau
1 Offline
Following...
WW2Chevy
1942 Chevrolet G506 1-1/2 ton 4x4 Army Cargo w/ winch
(Retro-roco)
Well, I can tell you I am very happy with the outcome so far... The wheels really make the truck look much better than before.
Philippe Jeanneau
The only other thing to do is to drill the extra 5 holes on the front hub and install the studs...
Philippe Jeanneau
That's great, love it!
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
Are your tires Hi-way/DOT rated? They look like tractor turf tires...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Those are not highway tires, but they're DOT rated... Remember it is not a 50 MPH truck. Good for rural roads, country roads. Not meant for highway, never my intent....
Philippe Jeanneau
Did the desert trucks use 10 studs on the front? Most regular trucks only used 5 like your px with flange?
Ed
Yes, they did, the second split wheel is fitted to an Australian Chevrolet truck, same hub; but God forbid I could find that part number anywhere! I will be drilling the front hubs for 5 extra studs on each on mine...
Philippe Jeanneau
The work continues, fenders are now widened but unfinished... happy with the result since it os very close to the wartime setup...
Philippe Jeanneau
Very nice, I love what you are doing.
Mac :{)
Thank you, can't wait to get it all done... Surprised to see that there isn't much interest out there other than I couple people I know in a project like this....
Philippe Jeanneau
Big Bolt Forum Moderator
that is turning out GREAT!
Mike
Philipj that is one nice truck, and a cool project you have embarked on. Please keep the updates and pictures coming.
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
Very cool project. Keep us updated.
Professional Novice
I think its really fun to see you doing this.
Brilliant that you have chosen this as a project and it looks very much like you are doing it right.
The originals caused way more trouble for the opposition than they cost in dollars or men. They were strictly ingenuity and make do on a tight schedule.
Some will complain that you are mucking up a nice Chevrolet, I think you are creating something much more than an original restoration could ever be. It will honor the brave men that built the first ones and risked their lives in the desert.
Mac :{)
Did you split the fenders or did you find some rare factory wide ones? I have two pair of wide fenders for '41-'47 GMC, didn't know if the made ones for earlier trucks.
Ed
Hello Ed, I split the fenders according to the military specs. of the time, which was a real pain in the neck,,, Do you think that the fenders you have would fit my truck? What model option truck did they fit originally? Can you post photos? Thank you.
Philippe Jeanneau
Hello Sweepleader,
It is fun in the sense that no one has done the early WB trucks in the US as far as I know, only the 41-43 models which reside in California... In the UK there are at least two of these early trucks reproduced, as the only one original survivor resides in the Imperial War Museum... I am trying to be as historically accurate as I can, but there are limitations. In terms of many parts (a lot has to be fabricated/finding used ones has proven very costly ) and even tires... Original wartime sizes are not available and one has to compromise...
Indeed, for such a small group of men they sure caused quite a bit of havoc against the Italian and German armies in Northern Africa...One great advantage was that many years earlier men such as Ralph Bagnold had traveled the desert with a small expedition and mapped many parts of the terrain, knowledge that was worth its weight in gold during the war... They were never expected to appear in many places and there they were, always harassing and disrupting the enemy convoys and destroying valuable supplies and fuel...
As for the trucks, initially they were purchased straight out of the GM dealerships in Alexandria and converted quickly but there were some units that came from the Indian Army as well... Out of nothing and very quickly they had to come up with trucks big enough to carry the weapons and supplies needed, but not too heavy as to be a problem in terms of weight or fuel consumption... That is why the (Ford) 4x4 units were tested but not utilized because they were impractical...
Now regarding possibly mucking up a nice truck, everything that I am doing can be reversed... I still have the original Budd wheels, the fenders would have to replaced and the rest of the truck will not be cut up... I have decided to keep the original cab after finding that there are no 1.5 ton open express trucks anywhere, especially 39-40 years... Despite wanting to present a small tribute to the men of the LRDP/LRDG group by doing this truck, I am all for preservation... I have kept the original 216, 6 volt system, saved every original W1 marked bolt I could keep,etc... So, I hope that I can be forgiven by the purists for doing this... My biggest let down, parts availability/prices and some vendors... I will just leave that there...
In terms of other support, I appreciate the words of encouragement by all members here, and I will try to post updates as quickly as I can. Still, I don't want to get off topic, but if anyone knows of someone that can help with good used parts it would be appreciated. Thank you.
Philippe Jeanneau
Phil,
Mine are a direct bolt on '41-'47 GMC. Only came on 1.5 ton that I know of, so have wheel cutout for 20" tires. I'll look for some px.
Ed
Hello Ed,
Thank you for posting the photos... I had never seen these before, very interesting.
Philippe Jeanneau
At last I have the widened fenders on the truck... A little more work remains, extending the fender braces and cutting the running boards on the inside so they can be bolted... For now I will leave them as they are resting on the inside of the fender... Later on I will have to extend all of them out to match the outside of the fender. A second set will be used for that on the front but more than likely the rears will have to be cut straight as well... I'm reluctant to go forward because of that at the moment...Need to rethink my options. Though overall I am happy to have replicated the war-time configuration on the truck...
Philippe Jeanneau
The truck is looking great. It is really going to be different when you get it all together.
It's hard to tell, is the front track width the same as the rear? The rear wheels look like they are inboard a ways compared to the fronts.
Mac :{)
Thank you... If I remember correctly, the rear tires fall within the old footprint of the dual wheels while the front is over about 1.5" from the original setup...
Philippe Jeanneau
That's turning out really nice!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Thank you, slowly gaining ground here... Next on the list is the work on the running boards.
Philippe Jeanneau
I just found this book in a box of favorites, I got it long ago, and I was wondering if you have seen it. There are a lot of pictures of your truck in it and many stories about it.
Mac :{)
Hello there,
I have seen some of these photos but not the actual book, though I think I know the series from the 80's... Looks great. Other photos inside?
Philippe Jeanneau
Yes, there are quite a few, I picked a couple that showed the truck best. There are pictures of Rommel and Montgomery and all those guys, a few tanks. There are more of the trucks but most of them are focused on something else, like the guns or the piles of stores. It is a fairly interesting read but there is not a lot of technical stuff on the trucks. There is a good one of the front wheel but it really does not show anything not in the pictures you posted. They call them "30 cwt", no mention of the drive line or model. It almost sounds like these were completely standard fare for the desert, nothing special, and they could be had at the local dealer. They look pretty special to me.
This was written by a historian, who I don't think was actually involved in the fight.
Do you have anything written by the guys that did the actual raiding or prepping of the trucks?
Mac :{)
You're correct in the sense that they got the first few trucks, 30 or 40 straight out of the Cairo dealerships and got minimum work done, such as the fenders and wider tires plus cutting the cabs... I do have a couple of documents detailing what was needed for these trucks from the LRDG... The first page deals with Ford 4x4 trucks and the second deals with the Chevrolet trucks...
Philippe Jeanneau
That is terrific! I love it.
Mac :{)
Glad you enjoyed it... This is information is very rare and came from someone that has really studied the subject.. I am very grateful for his help.
Philippe Jeanneau
Philippe, check your pm
Mac :{)
Here a few photos of the truck almost done, with a few small details to the body to be fixed... At last all the major modifications are done, and I was able to save the rear running boards and not having to extend the sides by almost 4" by modifying the front running board to match the rear...[img]http://[/img]
Philippe Jeanneau
Page 1 of 2 1 2
