0 members (), 90 guests, and 3 robots.
Topics128,031
Posts1,055,434
Members48,422
#1308982 04/29/2019 11:53 PM
I have 69 c10 with a 6 cylinder and 3 speed manual transmission. How much trouble is it to put a 1978 350 engine in it? Does the bell housing mount bolt up? Any help would be great.
56trucknut #1308986 04/30/2019 12:37 AM
Crusing in the Passing Lane
A 292 6 CYL.would work well tO.
ED
56trucknut #1309000 04/30/2019 2:13 AM
It should work fine, just get the v8 frame mounts. Will probably need a larger shroud for the radiator .
Tommy
59 apache 1/2t
261 short stepside
56trucknut #1309061 04/30/2019 6:20 PM
The bellhousing will be a direct bolt-in from the 6 to the V8. If you're running a 230 or 250 engine the motor mounts on the frame will be in the right place, also. A 292 will have an offset mount on the passenger's side, but if you're running one of them already, why bother with the V8?
56trucknut #1309104 04/30/2019 11:40 PM
Jerry, the 6 I have is original and is really tired. I have come across a known good v8 so I thought I would just swap rather than go through the overall process.
56trucknut #1309214 05/01/2019 8:24 PM
A C-10 with a 292 would probably have to have been special ordered when new. I don't think it was normally offered in the 1/2 ton trucks. C-30 and up would have been a more likely candidate for 292 power. They are rugged, powerful engines that will give a V8 a run for its money pulling a load, but they love their gasoline!
