| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 54 | I have 69 c10 with a 6 cylinder and 3 speed manual transmission. How much trouble is it to put a 1978 350 engine in it? Does the bell housing mount bolt up? Any help would be great.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | A 292 6 CYL.would work well tO.
ED
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | It should work fine, just get the v8 frame mounts. Will probably need a larger shroud for the radiator .
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | The bellhousing will be a direct bolt-in from the 6 to the V8. If you're running a 230 or 250 engine the motor mounts on the frame will be in the right place, also. A 292 will have an offset mount on the passenger's side, but if you're running one of them already, why bother with the V8? Jerry
| | | | | Joined: Jan 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 54 | Jerry, the 6 I have is original and is really tired. I have come across a known good v8 so I thought I would just swap rather than go through the overall process. | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | A C-10 with a 292 would probably have to have been special ordered when new. I don't think it was normally offered in the 1/2 ton trucks. C-30 and up would have been a more likely candidate for 292 power. They are rugged, powerful engines that will give a V8 a run for its money pulling a load, but they love their gasoline! Jerry
