4 members (Hotrod Lincoln, Otto Skorzeny, GRNHydra, 1 invisible), 91 guests, and 3 robots.
Topics128,089
Posts1,056,354
Members48,442
#1308798 04/28/2019 3:28 PM
I under stand that there must be a restriction somewhere so is it in the filter housing itself or in the lines,I just put any lines I could find when I put the filter on my 235 and wondering if that could be why the crank is scored and bearings down to copper with around 15,000 miles on it. Its time to change the oil and might eliminate the filter since the damage is done and will look into the correct lines before installing the replacement 235.
In the filter canister it self, not the lines.
If you dont have a restriction, you are better off without any filter and pipe plugging for obvious oil starvation issues.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
The crank looked like it was starved for oil even after being prelubed,I am going to eliminate the filter for now.
I do not run one either, rather change oil on a very early interval
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Ex Hall Monitor
Ex Hall Monitor
The restriction is on the stand pipe in the center of the canister. It's a small hole toward the top of the pipe.
Filter is off and the oil pressure climbs more rapid and now pegs the gauge,I do not think the replacement 235 will get a filter and will change the oil more frequently.
Just a scary guess: you might have oil passage blockage in the engine?
A pegged gauge might not be a good sign?
Using the original 30# gauge with a engine that should produce much more.
Looks like I found the problem and its the oil filter,oil pressure goes up more quickly and now 15 to 20 at idle where is was 5 to 10 before. Unfortunately the damage is done so time to get the new 235 read to drop in as I doubt it will last until fall so I know I will have a summer project.
