1 members (Cosmo),
86
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13088 10/18/2004 8:37 PM | Joined: Jul 2004 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 39 | I would like to thank everyone for all the previous post as I have been able to search and find much info.
My current problem is that I'm looking to put disc brakes on the stock front of my '49. Most of the kits say something like' "may not work with original wheels". SO I call Chevy Duty to ask which they will work with as I have stock 16" wheels and would like to keep them. The tech desk could not tell me if they would work and implied they probably won't & that I should go to a 5 lug as it is cheaper and there are more wheel/tire combinations. (which is true) But if I can use the original wheels with a kit that would be better.
Has anyone put on a disc brake kit and been able to use the 16 - 6 lut wheels? Is all it needs to work is a wheel spacer? I sure would like to stop and also keep the original wheel look and not have to change out the back wheels as well.
ALso what radial can be used on the 16's? THX ia49 | | |
#13089 10/19/2004 1:50 AM | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Same question for a '46 1/2 ton!
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | |
#13090 10/19/2004 5:41 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I used the CPP 6 lug kit on my '54 GMC. The 16" wheels fit but I had to grind just a bit off in a couple of places to get clearance. Nothing that would hurt the integrity of the wheel. I tried the spoked 16" and the 16.5" rims with the same result. | | |
