2 members (Hotrod Lincoln, Hush), 58 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
#130877 03/03/2004 5:10 AM
I am collecting parts to put together a '49 chevy half ton and my nephew has offered me a engine he took out of a caddy with the tranny. My question is how do I figure out how many cubes this baby is and also , just looking , it appears to me the oil pan with the front or mid sump on it might not clear the MII crossmember . I am still in the parts collecting stage and dont have the crossmember in the truck yet . Is there a different oil pan available to move the sump back some ? Has anyone done this combo yet ? Are there any other potential problems I am missing ?
#130878 03/03/2004 1:20 PM
http://www.hwforums.com/2089/
is a good place for caddy info but you'll have to give more info than what you did here.
what's it out of?
what year?
the pan you describe makes it out to be RWD...
i've subframed my 52 bourban and have a 500" eldo motor in it(may not stay with $2 a gallon gas)
i miss obscene phone calls...
#130879 03/09/2004 11:39 AM
Ive done a bit of reserach on the 500 caddy swap myself and these guys are recomended by people on other boards.
Try www.500cid.com
The projects section is great. Have a look at Crazy Joes VW!
From my research the best year is a 71 Eldarodo as it has the right sump. Remote oil filters etc are available. Just do lots of reading as the answers are out there. One of the guys here has done it, I think it might be 2-Ton but may be wrong.
Use the search on this place too for "500 caddy" as there has been some discussion in the lounge about this previously. Good luck.
Send David Hicks home - now!
"Better to be wrong and kill no one then right with mass graves" Albert Camus
#130880 03/09/2004 3:40 PM
http://www.500cid.com/mts/cat/tips.html
A little more than half way down they talk about availible oil pans and what year caddy motors had each...
I'd love a caddy motor!
