4 members (Shade Baby, LAROKE, Leo, John Dlugos), 222 guests, and 1 robot.
Topics128,101
Posts1,056,182
Members48,436
I have a 59 261 and the front seal on the crankshaft is leaking. When I pull it apart to replace the seal,if the balancer is damaged where the seal rides can a repair sleave be used on this balancer? of course the local parts people look at me like I'm from outer space when I say 1959 chevy 261 engine. Anyone know a part number?
Tommy
59 apache 1/2t
261 short stepside
Just tell them you want a “Speedy Sleeve” or use the search function in the bar just above your post. Type in Speedy Sleeve and read about it. RockAuto.com has them if you can’t find one locally. Good luck.🛠
Here are part numbers.
I assume the 235 & 261 would use the same part?
216, 235 and 261 use the same speedy sleeve as small block Chevrolet, so they are readily available.
My Blog
I found an old parts guy, and He said ok and went in the back and came out with the sleeve, didn't even bother looking it up. He did say it was the same as a small block.
Thanks for the help.
Tommy
59 apache 1/2t
261 short stepside
