0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | I have a 59 261 and the front seal on the crankshaft is leaking. When I pull it apart to replace the seal,if the balancer is damaged where the seal rides can a repair sleave be used on this balancer? of course the local parts people look at me like I'm from outer space when I say 1959 chevy 261 engine. Anyone know a part number?
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Just tell them you want a “Speedy Sleeve” or use the search function in the bar just above your post. Type in Speedy Sleeve and read about it. RockAuto.com has them if you can’t find one locally. Good luck.ðŸ›
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here are part numbers.I assume the 235 & 261 would use the same part? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 216, 235 and 261 use the same speedy sleeve as small block Chevrolet, so they are readily available.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | I found an old parts guy, and He said ok and went in the back and came out with the sleeve, didn't even bother looking it up. He did say it was the same as a small block. Thanks for the help.
