3 members (delky, Hanks custodian, Rich'sToys), 127 guests, and 3 robots.
Topics128,149
Posts1,056,817
Members48,454
EWW
Offline
Electrical is not my strength.
Picked up a running ‘46 earlier this week, but the headlights don’t work. It seems the problem is at the voltage regulator.
Here is the wiring diagram- https://imgur.com/gallery/Dqhj7zL
Here is the wiring as it sits now - https://imgur.com/gallery/XVgcWGi
The voltage regulator has b, a, f, written on it. Do I just need to swap the red and yellow wires?
Thanks in advance
It's hard to tell from the photos where the wires go, but it looks like the yellow wire is grounded to the V Reg case. If it is, it should go to the generator case/mounting bolt. The B (Bat) terminal on the V reg goes to the ammeter. The A (Armature) terminal on the V Reg should only go to the Armature of the generator. The F (Field) terminal should likewise only hook up to the Field coil connection on the generator. Make sure you have the two terminals on the generator properly IDed. Hope this helps.
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
EWW
Offline
Thanks, I think you are right.
Detail pic of gen. And v reg with cover off - https://imgur.com/gallery/pxDHxfN
EWW
Offline
Success!
...took me longer then it should.
