9 members (Gdads51, Donf, jmoore, TexasA&M48Truck, kades51, Otto Skorzeny, Frank50, Jon G, 1 invisible), 100 guests, and 1 robot.
Topics128,132
Posts1,056,379
Members48,441
1 Offline
Hello,
Can anyone tell me what the difference is grills between the smaller 1/2 - 1 ton grill and the larger 1.5 - 2 ton grills for the 1947-1953 style trucks?
Are the horizontal bars the same between the smaller and larger grillss? Is it only the vertical supports behind the grill that are different?
Thank you.
Check the tech tips’ Advance Design Spotting Guide.
Very concise article
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
1 Offline
Thanks for the response. I have looked throught that article but I do not see any notes on the actual differences between the grills on the smaller and larger trucks for 47-53
Haunting the SBP since 2001
The Loadmaster 1.5 & 2 ton outer grille bars are 1/2" taller than the Thriftmaster 1/2 -1 ton outer bars.
1.5 & 2 ton outer bars are the same width as the 1/2 to 1 ton bars.
Inner grill bars are the same for all grilles .
Vertical supports are 1.5" taller on the big truck grilles.
{ These specs. are for conventional cab trucks only }.
24601
Excellent info, MT -- Thx!
I should incorporate that info into the tech tip referenced above. Maybe when I get some time ... wink
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
F Online: Content
Mother Trucker: so you are saying the big bolt and small bolt grilles are the same width? There differences are only the height of the bars and the overall height? I would have not thought that... They "seem" wider and taller. Thanks!
Professional Novice
1 Offline
Thanks for the information Mother.Trucker.
