1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
1 Offline
Hello,
Can anyone tell me what the difference is grills between the smaller 1/2 - 1 ton grill and the larger 1.5 - 2 ton grills for the 1947-1953 style trucks?
Are the horizontal bars the same between the smaller and larger grillss? Is it only the vertical supports behind the grill that are different?
Thank you.
S Online: Content
Check the tech tips’ Advance Design Spotting Guide.
Very concise article
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
1 Offline
Thanks for the response. I have looked throught that article but I do not see any notes on the actual differences between the grills on the smaller and larger trucks for 47-53
Haunting the SBP since 2001
The Loadmaster 1.5 & 2 ton outer grille bars are 1/2" taller than the Thriftmaster 1/2 -1 ton outer bars.
1.5 & 2 ton outer bars are the same width as the 1/2 to 1 ton bars.
Inner grill bars are the same for all grilles .
Vertical supports are 1.5" taller on the big truck grilles.
{ These specs. are for conventional cab trucks only }.
24601
Excellent info, MT -- Thx!
I should incorporate that info into the tech tip referenced above. Maybe when I get some time ... wink
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Mother Trucker: so you are saying the big bolt and small bolt grilles are the same width? There differences are only the height of the bars and the overall height? I would have not thought that... They "seem" wider and taller. Thanks!
Professional Novice
1 Offline
Thanks for the information Mother.Trucker.
