4 members (walter74, Otto Skorzeny, Ponchogl, Cosmo), 103 guests, and 1 robot.
Topics128,049
Posts1,055,634
#1306927 04/13/2019 10:15 AM
I hope I post this in the correct area, I never know if door handles belong to body, inside, or...
In my '57 Suburban, for several months now, when I open the driver door from the inside, the handle does not go back to its "rest" position. As a result, the door does not latch when I close it, I have to push the inside handle forward to its place. Also, lately, it is getting harder to push the handle back in place, and I worry the issue is just getting worse. I have also noticed that there is more and more play in the shaft of the inside handle.
The outside handle works just fine.
Before I take stuff apart, can someone help and tell me what is going on, how to fix...? I drive my truck several times a week and would like to avoid being stuck with the door mechanism apart, not knowing what to do next...
Thanks!
'57 Chevy Suburban; '70 Chevy Impala.
I'd suggest you take off the door panel and have a look see.
Report back on what you find.
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
Big Bolt Forum Moderator
as Darcy said, take the door panel off, the "door control" that the inside door handle fits on is a pretty simple device and has a spring in it. I bet that spring is broken. You can take the door panel off in probably 10-15 minutes and back together in the same amount of time. You will probably end up just buying the door control and a new door handle (splines in the door handle can wear, I like to replace the handle when I replace the remote, unless it is perfect inside. Below is a link to the driver side one.
https://www.americanclassic.com/1955-59-Door-Control-Left/productinfo/18%2D827/
Mike
Thanks guys!
69Cudan thanks for the link for that part, I would even have known how it is called, let alone find it. I know about the spline wearing out inside the handle, so much so that I have had a pair of vice-grip instead of the handle for a couple of years now! At first, it was as a quick fix during a road trip, but I now find it quite fun to have this vice-grip there, and it reminds me of that trip!
