1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | Does anyone have any pictures of the hand throttle connection at the cardbutetor , have the cable bracket but nothing to the valve lever.
54 half ton
| | | | | Joined: Jul 2000 Posts: 2,193 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,193 | I don't have the throttle on my truck (it had it at one time), so I don't have a picture.
See the factory assembly manual, Section 6,Sheet 5.01 for a good diagram.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | Thanks this is very helpful | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | The attached pic shows the hand throttle connection on a Rochester B carb. You want to leave enough slack in the throttle cable so as to not effect idle and normal operation when not using the hand throttle. Pic | | | | | Joined: Sep 2018 Posts: 92 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 92 | My wire goes thru the loop of the cotter pin that was bent horizontal, no hangup whatsoever when the linkage is advanced. On the bottom side of the loop is a sliding brass fitting with set screw that tightens to the wire. I think its original factory. | | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | | | |
