5 members (Gdads51, joe apple, Otto Skorzeny, 1955 1 Series, Rexville48), 128 guests, and 1 robot.
Topics128,070
Posts1,055,896
Members48,428
#1306605 04/10/2019 1:03 PM
Does anyone have any pictures of the hand throttle connection at the cardbutetor , have the cable bracket but nothing to the valve lever.
54 half ton
Insomniac
Insomniac
I don't have the throttle on my truck (it had it at one time), so I don't have a picture.
See the factory assembly manual, Section 6,Sheet 5.01 for a good diagram.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Ex Hall Monitor
Ex Hall Monitor
Thanks this is very helpful
V
V Offline
The attached pic shows the hand throttle connection on a Rochester B carb. You want to leave enough slack in the throttle cable so as to not effect idle and normal operation when not using the hand throttle.
Pic
My wire goes thru the loop of the cotter pin that was bent horizontal, no hangup whatsoever when the linkage is advanced. On the bottom side of the loop is a sliding brass fitting with set screw that tightens to the wire. I think its original factory.
thanks for all the help
