4 members (Rick Brown, Bill Hanlon, 2-Ton, 5 Window 9434), 198 guests, and 1 robot.
Topics128,108
Posts1,056,238
Members48,437
#1306250 04/07/2019 1:42 AM
Anyone know the approximate weight of a 1953 GMC 250, and what size wheels would come stock on it? What is the ton rating for a 250? Thanks in advance. JP
Jon Patton #1306251 04/07/2019 1:45 AM
JP,
If you do not get an answer here, you might want to post this on oldGMCtrucks.com discussion board. Members there have a lot of GMC documentation.
https://oldgmctrucks.infopop.cc/eve
Jon Patton #1306270 04/07/2019 4:45 AM
3B Offline
Hy Jon Patton, we would need more information to give you anything more than an educated guess, too many variables. G.V.W. would be around 8000 lbs.,cab and chassis approximately 3400 lbs., panel truck 4200lbs., so I would guess the weight would be somewhere between those two numbers, hope that helps.
3B #1306274 04/07/2019 5:09 AM
Yeah I don't have the vin number. Hood on the truck has a 250 emblem (and looks to be the original hood), duals on the rear make it at least a 1 ton. Owner thinks it's rated at 1 1/2 ton. He is supposed to get me the tire size. He says he has a set of tubeless wheels that go with the truck (split rims are on the truck). 20 inch wheels should tell me that it's bigger than a 1 ton. Thanks JP
Jon Patton #1306304 04/07/2019 3:24 PM
I have a GMC 250, it’s a one ton. If the wheels are 20” I’d say that the truck isn’t a 250. At this point the hood could’ve been changed 50 or 60 years ago and hard to tell if original.
The above suggestion– check out oldgmctrucks website. Doesn’t take anything away from the Stovebolt but specializes in exactly these heavier gmcs. It’s a slow forum but lots of good info
1951 GMC 250 Open Express
1968 C10 Suburban
1971 C20 Pickup
My Dad told me "Son, never hit a man in anger- unless you're certain you can get away with it"
Jon Patton #1306305 04/07/2019 3:37 PM
Oldgmctrucks have a stand alone information website too with lots of information. With my Canadian 1 Ton, the GVW is stamped on a plate on the driver's door pillar.
1951 1 Ton Completed
truckernix #1306309 04/07/2019 4:20 PM
I went on oldgmctrucks.com last night, registered and got some of the same answers that I got here. I'm told that the pickups will have 17" wheels, 1 tons 18", and anything bigger 20". All I've seen of the truck is pictures in the ad. It's about a 5hr drive from me. Thanks to all! JP
Jon Patton #1306312 04/07/2019 4:50 PM
Yep. What do ya think it's worth?
Jon Patton #1306314 04/07/2019 5:21 PM
Sorry, no Craigslist links in the Garage Forum. You’se guys knows de rules!
Jon Patton #1306316 04/07/2019 6:00 PM
Moderator
Moderator
2 Online: Content
Sorry Martin, Not advertising, Just wondering if it was the one.
I'll know better next time.
Jon, I'll be sending you a PM tonight about a 48 I have.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Jon Patton #1306427 04/08/2019 7:03 PM
My '49 GMC 250 (1 ton) has 7.00 -18
BC
1960 C60 pasture art
Jon Patton #1306455 04/08/2019 11:04 PM
Ok thanks!
Jon Patton #1306459 04/09/2019 12:01 AM
My 50 GMC 253 has 7.00-17 tires and wheels, this was my dads truck and everything is factory
