3 members (rfs56trk, Wally / Montana, 55shaker), 113 guests, and 4 robots.
Topics128,078
Posts1,056,052
Members48,433
#1306217 04/06/2019 5:33 PM
Hi Y'all, The MA-1 carburetor I'm rebuilding has 2 settings I'm not sure of. The setting for the ON/Off fuel. And the setting for the carburetor choke this is the off setting.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Carburetion specialist
GUESSING you mean WA-1 instead of MA-1.
If so:
Carter made a bunch of different type WA-1 carbs; would need tag number to determine settings.
If the tag is missing, have the following at hand when you call:
(A) the carburetor
(B) wire brush
(C) straight blade screwdriver
(D) Phillips screwdriver (probably not needed, but nice to have everything if needed)
(D) pencil eraser
(E) strong light
(F) strong magnifying glass
(G) most importantly, a pair of young eyes.
Hopefully, the tag will be present, and the above list will be moot.
573-392-7378 (9-4 Mon-Tues central time).
Jon.
The Carburetor Shop
Jon, I all ready have the rebuild kits. Your employee set me up with them. So they all three use the same kit it's a 759.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
The Carburetor Shop
Have that paper, your web sight is great. OK looking at the pictures he is using a tape measure to measure the float movement, not as a normal tape measure but the width of the tape. This tape looks like a 1/2" wide tape. So I'll set the float movement that way.
Setting the Choke spring shall be by feel.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
This link will help you with the automatic choke adjustment:
http://www.thecarburetorshop.com/Automaticchokes.htm
Jon.
The Carburetor Shop
