| | | Forums66 Topics128,077 Posts1,056,014 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Hi Y'all, The MA-1 carburetor I'm rebuilding has 2 settings I'm not sure of. The setting for the ON/Off fuel. And the setting for the carburetor choke this is the off setting.
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | GUESSING you mean WA-1 instead of MA-1.
If so:
Carter made a bunch of different type WA-1 carbs; would need tag number to determine settings.
If the tag is missing, have the following at hand when you call:
(A) the carburetor (B) wire brush (C) straight blade screwdriver (D) Phillips screwdriver (probably not needed, but nice to have everything if needed) (D) pencil eraser (E) strong light (F) strong magnifying glass (G) most importantly, a pair of young eyes.
Hopefully, the tag will be present, and the above list will be moot.
573-392-7378 (9-4 Mon-Tues central time).
Jon.
Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Jon, I all ready have the rebuild kits. Your employee set me up with them. So they all three use the same kit it's a 759.
Julian Carter
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Have that paper, your web sight is great. OK looking at the pictures he is using a tape measure to measure the float movement, not as a normal tape measure but the width of the tape. This tape looks like a 1/2" wide tape. So I'll set the float movement that way.
Setting the Choke spring shall be by feel.
Julian Carter
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | This link will help you with the automatic choke adjustment: http://www.thecarburetorshop.com/Automaticchokes.htmJon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
