| | | Forums66 Topics128,006 Posts1,055,268 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Has anyone used the Innova 5568 timing light on a 6V system? Did it work? Is there any secret to make it function?
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | The inductive pickup will definitely work. Spark plug wire voltage is essentially the same on 6V and 12V systems, around 20,000V. The issue is the display, which Innova says needs between 10 and 12V. The solution is to use a separate 12V battery to power the light. From Innova's site: Does my timing light work on 6V systems?
Your timing light may be used on vehicles with 6-volt electrical systems by using the following connection procedure: 12-volt automotive battery required. 1. Connect the RED battery clip to the positive (+) terminal of a 12-volt battery. 2. Connect the BLACK battery clip to the negative (-) terminal of a 12-volt battery. 3. Using a length of 18AWG jumper wire, ground the negative (-) terminal of the 12-volt battery to a known-good ground on the vehicle under test.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2000 Posts: 2,187 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,187 | I won't buy an Innova product. I have an Innova OBD II reader. It doesn't read all the codes on newer cars as the software has changed. I tried to update the software but they don't support it. They want me to buy a new reader. The rep on the phone gave me a lot of BS.
Gord π¨π¦ ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I hooked it up to a 12v battery and the display for the volt meter worked fine and I even had a reading for dwell. But no tach or timing light flash.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | I hooked it up to a 12v battery and the display for the volt meter worked fine and I even had a reading for dwell. But no tach or timing light flash. The question I have is did the volt meter read the voltage of the 12v battery or the 6v? The inductive pickup should work when clipped around a plug wire to make the timing light flash. Have you tried it on a 12V vehicle? If it doesn't work there, maybe it's just pooched.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | It showed 12.5 volts. I think that was the voltage going into the gun. I had the pickup on #1 plug, the dwell lead on the distributor side of the coil and the extra ground wire as directed by the company website. I will give it a try on a 12V vehicle.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Just to close the loop on this, I solved my problem with the innova timing light. I just sent it back. Amazingly easy with amazon. So the new search for a timing light and tach officially begins now!
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I guess you know but.... if you got dwell, you then had to switch to timing, using a mode switch on the unit. You also needed to be in 4 cycle mode. You also can't have solid copper plug wire on no. 1. Don't look too long, most people just hook a 12V car, truck, lawn mower, battery charger..... to the light for the few times they check timing. Not a big deal and if a 6V light can't be used on 12V, that's no good.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I went through all the modes and nothing. Not sure about the dwell either. I had it set for 6 cylinders and 4 stroke too
