0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#130556 07/22/2004 6:03 AM
The air con kit from Old Air Systems for my 71 stepside arrived today.
Good quality stuff - I can't wait to start the install. Get ready for a whole slew of dumb questions.
Paul Domeier
Green71
#130557 07/27/2004 1:51 AM
Dumb Question #1:
I have a two pulley adapter on the V8 crank. I know I have to swap to a three pulley adapter... but what runs what?
I'll have the following accessories to run:
Power steering pump
Alternator
Compressor
Water pump/fan
I'm thinking from rear to front:
One belt for power steering pump only.
One belt for Water pump/fan and Alternator.
One belt for Water pump/fan and Compressor.
Sound about right?
The Old Air components are very well made, and everything is mounting up real easy so far... but the instructions are pretty weak.
Paul Domeier
Green71
#130558 07/27/2004 1:58 AM
Since you don't want the belts twisted as the motor turns you'll want to determine how the accessory pulleys line up with the crank pulleys and order the belts to match.
#130559 07/27/2004 3:38 AM
I assume you have a SB ...rather than mess around with all those belts...why don't you consider picking up a late model GM serpentine system at a junk yard. For about $100-200. you can make your life much simpler.(I installed an Old Air in my truck and the serpentine system saved me substantial time and aggravation).
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
#130560 07/28/2004 2:54 AM
Serpentine would be cool, but I don't want to drop any more dimes on hardware.
I think you guys misunderstood my question.
What I'm asking, is what is what belts run what accessory in a standard early 70's SB three belt system?
As in: Rear belt, middle belt, front belt.
Paul Domeier
Green71
#130561 07/28/2004 8:40 AM
Z
Z Offline
On my small block, rear power steering pump, center a/c, and front alt . Using vintage air, Alan Grove mounts. My SB has Steel Vortec heads. You can see my mounts here, before I added power steering
http://community.webshots.com/user/zeker6
Zeke
The Amish Connection
51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
#130562 07/28/2004 2:26 PM
That's what I needed. Thanks.
Sweet truck!
Paul Domeier
Green71
