9 members (Wayne67vert, DaveV, Phak1, Eisenholtz, Ponchogl, Bill Hanlon, 55shaker, Rusty Rod, TUTS 59), 159 guests, and 1 robot.
Topics128,049
Posts1,055,546
Members48,425
#1305059 03/28/2019 9:03 PM
1935 1.5 ton military
Hi,
The throttle linkage on my 1935 QB is all rods and springs, no cable. The the rod with the accelerator button on top passes through the floorboard, with no wear protection where it goes through the board. The hole in the board is now oval, and getting larger fast. I can no longer get full throttle because of the rod bending. It seems like GM would have placed some kind of pipe or at least a rectangle of metal there with a semi circle on it to provide a surface for the rod to bear on. Can anyone tell me what would have been there originally?
'35 1.5 ton military
thurman #1305227 03/30/2019 12:31 AM
Hi thurman i have a 1934 PA series and it seems to be the same all rods and springs the throttle through the floor on mine was also just trough timber..though mine is an Australian build body
1934 1-1/2 ton truck (Australia)
Hey, thanks for the info! Wow, I didn't think GM would have that poor a setup, even in 1935. I'm thinking a soft metal plate (brass maybe), rectangular with a half moon cutout on the top as a bearing surface. I'll think on it some more. Maybe two plates top and bottom to center it?
