7 members (Gdads51, frogfarmer, tclederman, JoeDude, Bill Hanlon, dt235sd, Jaison),
58
0
Mod | | | Forums66 Topics128,038 Posts1,055,536 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 28 1935 1.5 ton military | | 1935 1.5 ton military Joined: Aug 2018 Posts: 28 | Hi,
The throttle linkage on my 1935 QB is all rods and springs, no cable. The the rod with the accelerator button on top passes through the floorboard, with no wear protection where it goes through the board. The hole in the board is now oval, and getting larger fast. I can no longer get full throttle because of the rod bending. It seems like GM would have placed some kind of pipe or at least a rectangle of metal there with a semi circle on it to provide a surface for the rod to bear on. Can anyone tell me what would have been there originally?
'35 1.5 ton military
| | | | | Joined: Apr 2013 Posts: 18 'Bolter | | 'Bolter Joined: Apr 2013 Posts: 18 | Hi thurman i have a 1934 PA series and it seems to be the same all rods and springs the throttle through the floor on mine was also just trough timber..though mine is an Australian build body
1934 1-1/2 ton truck (Australia)
| | | | | Joined: Aug 2018 Posts: 28 1935 1.5 ton military | | 1935 1.5 ton military Joined: Aug 2018 Posts: 28 | Hey, thanks for the info! Wow, I didn't think GM would have that poor a setup, even in 1935. I'm thinking a soft metal plate (brass maybe), rectangular with a half moon cutout on the top as a bearing surface. I'll think on it some more. Maybe two plates top and bottom to center it?
