| | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Guys I have a 49 Suburban that I put a 69 Nova clip, a 1978 454 w TH400 tranny in. I am looking for a floor mounted shifter but prefer not to spend the big bucks for a Lokar or Gennie shifter. Has anyone got an idea of what would fit or could be modified to work. Or is there another manufacturere that is more reasonable?
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | B&M make some nice shifters for cars. You'd have to raise it up somehow so you can reach it, but the Quicksilver and the Megashifter work well. I have both of those. I'd say the Quicksilver is the easier one to use.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I put a Lokar shifter in my 55,I think it was worth the money.Tools and truck parts ,ya get what you pay for.Just my 2 cents worth. | | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | I am also using a Lokar shifter. It was money well spent. Very adjustable and easy to install. Its first rate equipment, plus it looks somewhat original. Most people still think its a manual transmission till I point out only two pedals on the floor. Joe | | | | | Joined: Feb 2005 Posts: 8 New Guy | | New Guy Joined: Feb 2005 Posts: 8 | I have a 58 with SB chevy and the 400 turbo and it has the B&M Quicksilver. It is works great but you gotta reach down to use it. The Lokar one like Joe has looks great and eliminates a center passenger. tough choices. | | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | If you don't mind bending down, I've often used a Pinto or Mustang Shifter.Then I used the switch back bracket that goes on the trany from a Chevy floor shift car.Or you could us the column shifter from an automatic truck. | | | | | Joined: Apr 2001 Posts: 162 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 162 | Not what you wanted to hear but I too use the Lokar on a turbo 350. Swap meet buy from a vendor for $160.00 maybe? Very easy to install and adjust. Looks good too and easy to reach. I don't know of any cheap solutions.
53 3100 1929 Ford Roadster Pickup 1934 Ford Pickup 68 Plymouth Satellite RR Clone 2 Door My Fleet
| | | | | Joined: Feb 2003 Posts: 104 Member | | Member Joined: Feb 2003 Posts: 104 | Try going to local auto salvage yard look at the cars that came with auto shifters on the floor .you can usually pick something like that for ten to twenty dollars ,There is a lot of things on other vehicles that you can make work and save a lot of money. good luck old navy 51........... | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Well Guys I bit the bullet and bought a Lokar. It actually arrived today and looks good. I figured what the hey you get what you pay for and I need to keep moving forward. I do a lot of salvage yard & swap meet purchases but don't have the time right now so I pulled out the wallet!!
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | 49bourbon,I think you made a wise choice,the Lokars are quality stuff. | | |
