0 members (), 146 guests, and 2 robots.
Topics128,162
Posts1,056,939
Members48,458
#1304917 03/27/2019 10:16 PM
Due to rust, I couldn't get my cylinder filler top off my reservoir so I took it out from under the truck thinking I could drill into it and put a tap into it and
back it out. That didn't work so now I have a master cylinder with a hole in the filler top that still won't come off. I am not sure if the cylinder is bad or not,
but from the previous owner I was led to think it was ok. Anyway, I'm not sure what to do now. I don't think the top will come off as it is rusted on so badly and a shop
has tried with no luck. Does anyone have any ideas for me ?
Troy
1963 Chevy C60
Big Red Chevy
1951 GMC 453 Series 3-Ton Army Truck
Crusing in the Passing Lane
Heat from the top, need to be willing to sacrifice top, might have to split and peel off.
Ed
Thanks Ed, I will try heating one more time. I appreciate the response !
Troy
Troy
1963 Chevy C60
Big Red Chevy
Since you have it out, why not soak it in rust remover for a day or two, then try again? 🛠
I will try that too. I’m sure open to all suggestions at this point.
Thank you sir
Troy
1963 Chevy C60
Big Red Chevy
tlm Offline
If all else fails consider mig welding a nut to it. Between the heat and additional torque using a wrench???done similar with the lock ing lugnuts that need a key.
Thanks tlm for the suggestion, I appreciate it !
Troy
1963 Chevy C60
Big Red Chevy
