| | | Forums66 Topics128,268 Posts1,058,378 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 74 Member | | Member Joined: Sep 2004 Posts: 74 | OK, for the reason as to WHY I have a 235 sitting around doing nothing, here's a bit of history. Back in the day (around 66-67), when my dad was in high school and lived in the Chicago 'burbs, he bought his dad's 67 Bel Air (235, 3spd column shift). Being a hot-rodder, and not being able to find a suitable V8, he rodded the 235. It now has a 2-1bbl intake modified to take corvair carbs, headers, ported and polished head, 3/4 race cam, 10:1 compression, high volume oil pump and he used to run a dual exhaust. Now, it's sitting in the basement languishing (he found a 283 eventually and threw that in before he sold the car) totally complete, minus the carbs, which I don't think would be that hard to find.
On the other hand, the truck now has a 250 that's kinda shady. It doesn't have any knocks or rattles, but it's charging system is so-so, it needs a new distributor, rockers and has a burned valve, and the stock 1bbl carb. As it is, it runs pretty good, and has quite a bit of power.
I suppose I have 2 questions -
First, which engine would you put in my 67 C10? Second, I've got the bellhousing to swap engines, but what kind of modifications to the engine mounts will I have to do? Are there engine mounts out there that I could use?
I really appreciate your time. Thanks.
I am not bound to please thee with my answers. - William Shakespeare 1967 C10 1983 Olds Delta 88
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | -------------------- I am not bound to please thee with my answers. - William Shakespeare Originally posted by Matt McD: Back in the day (around 66-67), when my dad was in high school and lived in the Chicago 'burbs, he bought his dad's 67 Bel Air (235, 3spd column shift). Could it have been a '57 Bel Air instead of a '67? I'm going to assume so, since the 235 wasn't made after 1962. First, which engine would you put in my 67 C10? Second, I've got the bellhousing to swap engines, but what kind of modifications to the engine mounts will I have to do? Are there engine mounts out there that I could use? If your basement motor really is a 235 I would stick with the 250 or look for another motor. The 235 is designed to be mounted at the front and to the bell-housing. The '67 truck is designed for a side-mount motor. That's my two cents.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2004 Posts: 74 Member | | Member Joined: Sep 2004 Posts: 74 | Crud, I was stuck in one frame of mind. No, it is definitely a 235, and it came out of a 62 bel air. The truck is a 67 with a 250. OK, now I think I've got it all worked out. Anyway, the mounting locations are different? Oh well. it was a fun idea while it lasted.
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Matt, if you look at your 235 you should find it has side mounts. You can fab something up to work without a lot of effort. The stock pickup 235 used the front mount. Biggest issue will be fitting the engine between the frame rails. That you can check with a tape measure.
For a rear mount use the cross-member mount on your tranny. Using the bell-housing for the 235, your tranny in your 69 should bolt up, assuming you have a 3 speed.
Fred 52 3600 69 C-10
| | | | | Joined: Sep 2004 Posts: 74 Member | | Member Joined: Sep 2004 Posts: 74 | Cool. The engine and truck are about 150 miles away from me, so I can't really do any physical fabbing or measuring just yet, but I'll let you know the next time I go home. Thanks!
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | A 1962 is a little different story than the '57 I imagined you meant. I've never taken a six out of a '62. I owned a couple of 62's when I was in high school but both were factory 283s...
But my reaction is still the same. I wouldn't do it. Its the wrong motor for that truck. A '67 would make more sense with a 292 or a small V-8.
