4 members (qside, MOTOXFAMILY, 55shaker, dt235sd), 170 guests, and 3 robots.
Topics128,268
Posts1,058,379
Members48,485
#130486 09/16/2004 4:31 AM
OK, for the reason as to WHY I have a 235 sitting around doing nothing, here's a bit of history. Back in the day (around 66-67), when my dad was in high school and lived in the Chicago 'burbs, he bought his dad's 67 Bel Air (235, 3spd column shift). Being a hot-rodder, and not being able to find a suitable V8, he rodded the 235. It now has a 2-1bbl intake modified to take corvair carbs, headers, ported and polished head, 3/4 race cam, 10:1 compression, high volume oil pump and he used to run a dual exhaust. Now, it's sitting in the basement languishing (he found a 283 eventually and threw that in before he sold the car) totally complete, minus the carbs, which I don't think would be that hard to find.
On the other hand, the truck now has a 250 that's kinda shady. It doesn't have any knocks or rattles, but it's charging system is so-so, it needs a new distributor, rockers and has a burned valve, and the stock 1bbl carb. As it is, it runs pretty good, and has quite a bit of power.
I suppose I have 2 questions -
First, which engine would you put in my 67 C10?
Second, I've got the bellhousing to swap engines, but what kind of modifications to the engine mounts will I have to do? Are there engine mounts out there that I could use?
I really appreciate your time. Thanks.
I am not bound to please thee with my answers. - William Shakespeare
1967 C10
1983 Olds Delta 88
#130487 09/16/2004 4:52 AM
Quote
Could it have been a '57 Bel Air instead of a '67? I'm going to assume so, since the 235 wasn't made after 1962.
Quote
If your basement motor really is a 235 I would stick with the 250 or look for another motor.
The 235 is designed to be mounted at the front and to the bell-housing. The '67 truck is designed for a side-mount motor.
That's my two cents.
#130488 09/16/2004 5:07 AM
Crud, I was stuck in one frame of mind. No, it is definitely a 235, and it came out of a 62 bel air. The truck is a 67 with a 250. OK, now I think I've got it all worked out. Anyway, the mounting locations are different? Oh well. it was a fun idea while it lasted. frown
1967 C10
1983 Olds Delta 88
#130489 09/16/2004 5:27 AM
Matt, if you look at your 235 you should find it has side mounts. You can fab something up to work without a lot of effort. The stock pickup 235 used the front mount. Biggest issue will be fitting the engine between the frame rails. That you can check with a tape measure.
For a rear mount use the cross-member mount on your tranny. Using the bell-housing for the 235, your tranny in your 69 should bolt up, assuming you have a 3 speed.
Fred
52 3600
69 C-10
#130490 09/16/2004 5:35 AM
Cool. The engine and truck are about 150 miles away from me, so I can't really do any physical fabbing or measuring just yet, but I'll let you know the next time I go home. Thanks!
1967 C10
1983 Olds Delta 88
#130491 09/16/2004 6:25 AM
A 1962 is a little different story than the '57 I imagined you meant. I've never taken a six out of a '62. I owned a couple of 62's when I was in high school but both were factory 283s...
But my reaction is still the same. I wouldn't do it. Its the wrong motor for that truck. A '67 would make more sense with a 292 or a small V-8.
