7 members (Gdads51, Guitplayer, Donf, FAST55, papas52, DougH6100, Hanks custodian), 82 guests, and 2 robots.
Topics128,162
Posts1,056,950
Members48,458
#1304773 03/26/2019 10:03 PM
I'm unable to find a standard part from any of the vendors to seal the gap between the heater motor and firewall. My truck came with a thin piece of rubber, but it didn't hold up well.
Is there a standard part, or what are people using for this?
Greg Brown
This is the correct part, steel with rubber bonded to it. Since your motor is non-stock I am unsure how tight it may seal. The original fits like a boot surrounding the motor. I am also unaware of a reproduction for this, post in the Swap Meet someone may have a spare.
https://www.flickr.com/photos/advance-design_parts_co/8129342505/in/album-72157631868452754/
https://www.flickr.com/photos/advance-design_parts_co/8129343557/in/album-72157631868452754/
Brad,
That flickr site will not let me view, unless I log in.
Brad,
Greg,
There were two optional/accessory heaters. Maybe this gasket/seal set will work for yours?
Greg,
Check your local Home Depot, Lowes or hardware store for something you can adapt from their weatherstrip section. I have made gaskets out of old rubber Mouse Pads.
You could also use something like this.
https://www.grainger.com/category/m...ibration-control/vibration-isolator-pads
Sometimes we have to get creative.
Harold
Harold
Here's repurposing something from Kohler after a bathroom remodel several years ago. Cutting the 3 tabs helps the look.
Former BMW Rider
Former BMW Rider
I cut my heater motor seal out of an old inner tube. Seems to work just fine!
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
I used a scrap piece of pond liner.
Crusing in the Passing Lane
Appropriate size rubber fuel line would work, just roll it in.
Ed
Nice - that's the way to do it!
1951 Chevy Panel Truck
Thanks for all the suggestions. I think the original in my truck may have been old innertube, but it hardened and cracked over time.
Greg Brown
Whoaw!! HandyAndy seems to have a circular metal ring that is attached to firewall which goes around the wiper motor, getting sealed up with a piece of innertube, whereas Greg Brown, you do not have such a ring per your pics. So unless you have such a metal ring, you will need to find another way to seal between the motor and firewall.
Craig
I'm with Brad Allen on this, your motor is non-stock, from the looks of it, the motor barely protrudes out past the firewall.
The stock motor sticks out past the firewall, which gives you the ability to slide a gasket around the motor housing to make a seal.
With the motor you have, it could be covered with a round metal plate. You would have to cut off the access screw threads.
Original Posters Picture of Heater Motor
It is kind of hard, to tell, just how far the motor sticks out past the firewall, because of the angle the picture was taken.
One of the members building an AD hot rod used an oil filter canister welded to the firewall to cover the heater motor. If you didn't want to weld it on, you could build something with a flange and bolt it on. Here's a link to what he did. Firewall heater motor cover
Haunting the SBP since 2001
Jim Carter offers the blower motor rubber seal & the ring retainer.
http://www.oldchevytrucks.com/cart/product.asp?prodid=MEH200&i=|||||
http://www.oldchevytrucks.com/cart/product.asp?prodid=MEH254&i=|||||
I have run into similar problems when I restore Fresh Air heaters as most get updated with 12 volt motors.
All of the 12 volt motors are smaller in size compared to the original 6 volt motors.
The 12 volt motors are too small to fit the hole in the firewall or the original seal.
I have devised an ingenious grin work around for getting everything to seal { & it will work in this case also }
First get an old original 6 volt blower motor that is fried.
Take it apart & get just the front cover off the motor.
Slide the cover into the firewall seal & retainer.... & silicone it in place.
Then take the cover with the seal attached & install it over the new {smaller} blower motor protruding out from the firewall & secure it with 3 sheet metal screws.
The finished installation looks just like an original blower motor installed on the firewall.
