0 members (),
38
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | I saved two front fenders from scrap yard. They were off of a 1951 GMC 1/2 ton truck. The fenders have a "golfball" size hole in the front below the headlight. What are the small holes? Panel front fenders? Thank you in advance.
1950 Chevy 3100
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The location of the parking light is different for different year GMCs.
1/2 ton front fenders are the same for all models of GMC light trucks (1/2 - 1 ton trucks)
Last edited by tclederman; 03/27/2019 11:39 AM. Reason: Deleted a later post with incorrect information about differences.
| | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | Do the GMC fenders fit a Chevy 1/2 ton truck or are they a different fit? Again, Thank you
1950 Chevy 3100
| | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | That makes 100% sense. Thank you!
1950 Chevy 3100
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | For some reason, my memory is clicking here, I believe that the 47-48 GMC park lamps are smaller in diameter than the 49-53. Maybe I read that somewhere.
More veteran intel will confirm, hopefully. 😎 | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | The only difference between '47.2-'53 front fenders is that the GMCs have that hole under the headlight for the parking light. I have a '49 and a '52 Chevrolet with a GMC front fender on each one of them. All I had to do was weld a patch inside the parking lot holes. Carl
