8 members (KEVINSKI, mick53, 55shaker, Peggy M, Gdads51, Hanks custodian, MickeyP, 1 invisible),
148
Mod | | | Forums66 Topics128,089 Posts1,056,137 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2018 Posts: 65 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 65 | Hi Guys, I’m working on a 48 gmc. Switched over to a dual master, 10 lbs residual check valve to front and back, and new wheel cylinders at all 4 corners. Now the problem is at the rear only half the wheel cylinders are working. I’ve bleed the entire system twice and still only actuate on one side only. Any ideas? Thanks | | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | How are you able to look inside the brake drums to see what's moving? Jerry
| | | | | Joined: Sep 2018 Posts: 65 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 65 | I have the drums off when I step on the pedal. | | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | You don't have a problem, then. Finish putting the brakes together, adjust the shoes properly, and drive on. Jerry
| | | | | Joined: Sep 2018 Posts: 65 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 65 | Hi Jerry I’m not questioning your knowledge but can you explain how putting the drums on changes anything? Being a novice to brake repair I can’t get my head around it without some understanding. Thanks | | | | | Joined: May 2015 Posts: 11,065 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,065 | I have the drums off when I step on the pedal. Then the wheel with the weakest shoe return springs will be the only one to move. The fluid takes the path of least resistance. Putting the drums on gives the shoes on both sides essentially the same resistance as soon as they contact the drums. Like Jerry said, put the drums on, adjust the brakes and go.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | Ditto- - - -with nothing to push against, whichever piston meets the least resistance will move while the other one stays stationary. With the drums installed and the adjustment done, neither shoe will be able to travel more than a few thousandths of an inch without one of the linings contacting the drum. Then the other one will move into contact and the stopping will begin. There won't be more than a fraction of a second's difference in the application of both shoes- - - -not enough to measure with any sort of accuracy. Jerry
| | | | | Joined: Sep 2018 Posts: 65 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 65 | Thanks guys, that makes sense. I appreciate the clarification and the help. | | |
