2 members (Barry Martak, lumbersawyer), 139 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
I want to install a new gas tank for my 1950 Chevy 1/2 ton pickup. I do not want to place it in the cab. What is a good alternative site on the truck? What gas tank should I buy? Any suggestions?
Thank you!
You could go to the pre- early '49 style which is between the frame rails under the bed. I suspect a good donor would be a **** Ranger or van which have long skinny tanks that fit well under the bed. A Jeep CJ or YJ tank (or two) would work well too since they are easy to get ahold of and they fit between the frame rails. You can get them in aftermarket high capacity versions in metal or plastic.
Paint & Body Shop moderator
There was an article in the January 2000 issue of Street Rodder about an aftermarket gas tank for 1940-54 GM trucks. The tank kit mounted to the rear frame crossmember.
The kit was made by TANKS, INC., Box 400, Clearwater, MN 55320
Phone (320) 558-6882
Come to the Great Lakes GABfest
Get all the details here!
Thank you guys sooooo much!
Richie, don't you mean "tank" you?
Junior Member
Junior Member
go to www.stovebolt.com look up bill pecks 52 gmc. i used a fuel cell near the rear crossmember. there is a pic, very easy job. grin
i have heard, not tried... yet... wink
that early mustangs work well, fit right between the rails.
also, there was something that i read once about using a 69-72 blazer tank. i think it may hang down a touch too much.... can't remember.
the biggest problem with any of these is the plumbing of the filler spout. do you want it just in the bed, or do you want to do something slick, like behind the licence plate or something else? one of the big things to look at with the jeep tanks is where the filler spout comes in....
Build 'em to Drive 'em
Junior Member
Junior Member
Why would it be safer to have the gas tank outside the cab? Besides the obvious if there ever was an explosion. But i would think it would be safer in the cab where it is protected?
*under construction* 1962 Chev truck: Bagged & bodydropped, shaved, custom made clear tailights & roll pan, custom made aluminum parts.
http://www.geocities.com/philswebsite2003/
PJ,
Saw pictures of a mid-50's Fjord with the gas tank in the cab, that had been rear-ended on I-5 south of Seattle. Pushed the bed into the cab, crushed the tank, rubber connector on filler neck came off. Two people dead.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
Go to www.brotherstrucks.com they have custom tanks that fit in the rear under the bed. Its probably what I will go with.
grin
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces
2000 GMC Serria 1500 SL 4x4
where exactly does the tank in the rear go.
is it toward the front abouve the drive shaft?
after the diff. between railings
just trying tofigure best location.
should i use a fuel cell?
Do not put it above the driveshaft! Best location is behind the rear axle as high in the frame as you can get it. You can run along the frame like the mid 80's Chevy truck. Joe
Richie you might want to check out Fatfenders site, here he has a van gas tank in one of his projects.
Send David Hicks home - now!
"Better to be wrong and kill no one then right with mass graves" Albert Camus
