| | | Forums66 Topics128,281 Posts1,058,488 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 61 Member | | Member Joined: May 2001 Posts: 61 | I want to install a new gas tank for my 1950 Chevy 1/2 ton pickup. I do not want to place it in the cab. What is a good alternative site on the truck? What gas tank should I buy? Any suggestions?
Thank you! | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You could go to the pre- early '49 style which is between the frame rails under the bed. I suspect a good donor would be a **** Ranger or van which have long skinny tanks that fit well under the bed. A Jeep CJ or YJ tank (or two) would work well too since they are easy to get ahold of and they fit between the frame rails. You can get them in aftermarket high capacity versions in metal or plastic.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Dec 2000 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2000 Posts: 163 | There was an article in the January 2000 issue of Street Rodder about an aftermarket gas tank for 1940-54 GM trucks. The tank kit mounted to the rear frame crossmember.
The kit was made by TANKS, INC., Box 400, Clearwater, MN 55320
Phone (320) 558-6882 | | | | | Joined: May 2001 Posts: 61 Member | | Member Joined: May 2001 Posts: 61 | Thank you guys sooooo much! | | | | | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | Richie, don't you mean "tank" you? | | | | | Joined: May 2001 Posts: 2 Junior Member | | Junior Member Joined: May 2001 Posts: 2 | go to www.stovebolt.com look up bill pecks 52 gmc. i used a fuel cell near the rear crossmember. there is a pic, very easy job.  | | | | | Joined: Sep 2002 Posts: 49 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 49 | i have heard, not tried... yet... that early mustangs work well, fit right between the rails. also, there was something that i read once about using a 69-72 blazer tank. i think it may hang down a touch too much.... can't remember. the biggest problem with any of these is the plumbing of the filler spout. do you want it just in the bed, or do you want to do something slick, like behind the licence plate or something else? one of the big things to look at with the jeep tanks is where the filler spout comes in....
Build 'em to Drive 'em
| | | | | Joined: Oct 2002 Posts: 43 Junior Member | | Junior Member Joined: Oct 2002 Posts: 43 | Why would it be safer to have the gas tank outside the cab? Besides the obvious if there ever was an explosion. But i would think it would be safer in the cab where it is protected? | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | PJ,
Saw pictures of a mid-50's Fjord with the gas tank in the cab, that had been rear-ended on I-5 south of Seattle. Pushed the bed into the cab, crushed the tank, rubber connector on filler neck came off. Two people dead.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | Go to www.brotherstrucks.com they have custom tanks that fit in the rear under the bed. Its probably what I will go with.
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces 2000 GMC Serria 1500 SL 4x4
| | | | | Joined: Nov 2002 Posts: 33 Member | | Member Joined: Nov 2002 Posts: 33 | where exactly does the tank in the rear go. is it toward the front abouve the drive shaft? after the diff. between railings just trying tofigure best location. should i use a fuel cell? | | | | | Joined: Feb 2000 Posts: 5,269 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,269 | Do not put it above the driveshaft! Best location is behind the rear axle as high in the frame as you can get it. You can run along the frame like the mid 80's Chevy truck. Joe | | | | | Joined: Jun 2002 Posts: 96 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 96 | Richie you might want to check out Fatfenders site, here he has a van gas tank in one of his projects.
Send David Hicks home - now! "Better to be wrong and kill no one then right with mass graves" Albert Camus
