| | | Forums66 Topics128,183 Posts1,057,262 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 128 Shop Shark | | Shop Shark Joined: Feb 2019 Posts: 128 | So I got that old 370 home and I'm gonna start on that axle swap next week. But this rig looks like it's straight hydraulic brakes. Is it possible to convert these hydraulic axles to air? I don't really know how air works.
Is it possible? Can I do it or should I try a truck shop?
Or should I just re-plumb for Hydraulic. I'm really liking the air brakes though.
Hoka Hey! Spartan
1959 Chevy Spartan 100 "Battle Wagon" 2008 Buell Lightning "War Horse"
| | | | | Joined: Feb 2016 Posts: 1,996 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,996 | If you have money and time you can do anything, for a do it yourself job I wouldn't consider it, you will have to re-invent the wheel.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If you really want to do it, get a similar or same truck on air and switch everything over, or put your body on the other truck.
You will need a driver's license authorization for air.
Pretty easy to get all new juice brake parts, and a whole lot easier.
Ed
| | | | | Joined: Feb 2019 Posts: 128 Shop Shark | | Shop Shark Joined: Feb 2019 Posts: 128 | Ed, we don't need a different license for air brakes out here so thats not an issue. The reason it's not easy to do a body swap is because one truck is an LCF style and the other is a conventional cab. The front axle is in a very different spot.
Gents I understand the "anything with enough money" but what I don't get is what scale you're talking about. 10,000? because that's obviously not an option at that price. But if it were $1500, I would entertain that. I understand that the actuation is different, but are the drums and pads and everything else different? Could I just pull the whole brake assemblies off the axles and swap them? I just don't know how universal they are.
Hoka Hey! Spartan
| | | | | Joined: Feb 2016 Posts: 1,996 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,996 | Depending on if you have a donor chassis or if your starting from scratch with new current products. With all new parts or a combination of donor and new $1500 won't even get you in the ballpark. Like Ed recommended, try to find a rig that you can swap axles and the rest of the air system.
| | | | | Joined: Feb 2004 Posts: 29,880 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,880 | You're probably about to create a couple of pieces of yard art- - - - -two ruined rigs that will never be roadworthy again. Jerry
