| | | Forums66 Topics128,187 Posts1,057,311 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2019 Posts: 1 Moderated | | Moderated Joined: Mar 2019 Posts: 1 | I have a 54 chevy 3800 panel truck and would like to put newer type rims on it, it is 8 lug, will rims off a 2005 chevy 2500 8 lug fit? I heard they will hit the tie rods ? does any one know what kind of rim I can use? Can I use wheel spacers? Thanks , stuck without wheels in Ma. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | https://www.etrailer.com/Tires-and-Wheels/Dexstar/AM20766.html#/I put these on my 9430 (Canadian 1 ton) and I clear my tie rod ends by about 3/8”. I run 215/85/16 tires. It dropped the tire height a little bit but that ole one ton sure rides nicely. | | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | I used these same rims on my 53 Chevrolet 3600. They fit perfectly!!
| | | | | Joined: Mar 2007 Posts: 55 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 55 | Excellent info.
Will the original hubcaps work with these? | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I have heard that they will but with an asterisk...
You have to reuse original hub cap clips (or, yeesh, buy reproductions) and drill the rims, rivet or weld on the clips and you’re good to go.
I have original clips from my old rims but haven’t built up the courage to drill into these nice rims.
