5 members (klhansen, 5 Window 9434, farmallb, Peggy M, 1 invisible), 59 guests, and 3 robots.
Topics128,024
Posts1,055,393
Members48,422
#1303070 03/14/2019 11:32 PM
How are you guys getting your floor mats installed around your pedals? I have a '54 6100. Not sure how much piecing would need to be done.
Reproduction mat from Jim Carter is already marked where to cut for pedals.
Not marked and no instructions on cutting for gear shift or parking brake unless they’ve figured that out in the past year.
1952 Chevrolet 3800 pickup
---All pictures---
That product is marked, but it was my experience they were incorrectly marked for several of the openings needed. This was for my ‘46 Chevy 1/2 Ton. Luckily I checked before cutting anything. I then made a template, using grocery bags. Checked and rechecked the template fit, then using it marked the back of the repop mat and cut. I was happy with the results.
How did you guys get your cut holes over the pedals without making the holes too big?
Big Bolt Forum Moderator
on my 59, I cut a slit in between the holes for the clutch and brake pedals. Not sure on the older ones,
Mike
The AD floormat from Carter’s is supposed to be recently updated and better than previously offered. I don’t have experience with the older reproduction.
The recent one is easy to cut perfectly, well marked on back side, instructions included (but not for shifter or brake).
---All pictures---
Grigg #1303097 03/15/2019 2:09 AM
Can you show a picture of yours as installed?
The upper brake pedal arm and the lower brake arm are bolted together outside the cab on the '55-59 trucks, so you unbolt the two arms to remove the upper arm, install the mat and then reinstall the arm through the mat hole/floor...are AD trucks done the same way?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
It'll be several months.
---All pictures---
Fox Offline
I made my own. It took a while but they turned out pretty good. I spent about $22 US on the material and then cut it to fit. I used a paint pen to mark the holes as I laid it in. Then I punched an awl through and then opened up the holes with a die grinder with a burr bit in it. I built it in 3 pieces, which overlay each other, so it would lay perfectly flat. I made it so I have to remove the brake and clutch pedals to fully pull the mat out, but a couple short slots would fix that if a guy didn’t want to. I have about 6” of overlap on the pieces. To help anchor the mat, I put flat washers on the rubber over top of the studs for the old “sound deadener/floor mat” and secured it with a tight fitting E clip.
Time consuming to make? Yes. Would I do it again? Yes, and I will be on the next AD.
https://photos.app.goo.gl/2Ei4tNp2WRGyyGyc8
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Fox ,that looks great,where did you purchase material?
Fox Offline
Pat,
My apologies, the material was $22/ea x 3. It’s bad how a guy forgets stuff from only a little over a year ago. I have used the leftovers in many other areas as I do house fix ups, shop tool box lining, anti squeak pads, couch feet pads, etc. It is handy matting. I’m not sure if the price makes it justifiable vs a pre made LMC/Classic Parts rubber mat. I’m still doing it this way on my 2nd AD.
If you’re still interested here is a link:
https://www.homedepot.com/p/Technof...ber-All-Purpose-Mat-F3000-15HD/301061401
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
7
7 Offline
Thanks Fox, that is good info and I was looking in HD for something like it, my local store doesn't stock it but can have it delivered. I'll need to make my own to fit my LCF due to the floor and toe board being different than the 3100 - 3800 trucks.
Here's some pics of the felt pad and floormat in my 1954 3604, may be of some help.
Floormat is Jim Carter FL102
Felt Pad is American Classic FMF47
Ron - - Dusty53
1954 Chevy 3604
Fox #1305975 04/04/2019 9:54 PM
Thanks Fox,trying to decide which way to go on 66 l60, make my own,or modify a c10 maat,Pat
Mike B smile
Yes, AD trucks have two piece pedal arms. Simply unbolt and remove the upper half of the pedal arm, cut small hole in your flooring of choice, and bolt your pedal arms back together.
1951 Chevy Panel Truck
