6 members (BarryP, klhansen, dt235sd, Youngin' Tut 59, DadsFirstPickup, 1 invisible), 70 guests, and 2 robots.
Topics128,139
Posts1,056,758
Members48,454
On my last project I ask my customer if I could have some scrap tubing for brake line on my 53 1/2 ton. They gave me two 200 foot rolls. Wil this work for my truck. I'm running Wilwood 12.88" disk 4 piston rear and 6 piston front. Here are the numbers on the tubing.
Made in Canada, 0.250" XO .035" A ASTM A249/A209 ASME 5A-249 & BRS-75 TP 304/304L HT #SE00444 welded NDE 2018/02/27 22:10
That should work.
Copper nickel is so much easier to work with, even if I had 200’ of stainless I wouldn’t want to use it on my truck. (I have used it before)
•1952 Chevrolet 3800 pickup
---All pictures---
There's one word in that description that gives me a little pause- - - - -"welded". Are you willing to bet your life on that tubing, and/or the lives of the people who share the road with you? Most brake line tubing is "seamless". It might work OK, but be sure your liability insurance has a very high limit.
Good point Jerry, although that ASTM number corresponds to a tensile yeild strength of at least 25,000 psi. It's normally specified for instrument tubing, used for pneumatic instrumentation or relatively low pressure (~100 psi) liquid service.
For comparison, copper nickel brake tubing is rated for 16-22,000 psi.
Making double flared ends for stainless steel would be enough for me to balk on that tubing. I do use stainless steel brake lines on my trucks, but they were bought from a supplier and are already the right length, with all of the correct bends, with flared ends.
Carl
I have also used “store bought” “fitted” stainless steel lines on three 3100 trucks - no leaks, after carefully seating the tubes/fittings.
They are worth every dollar of the costs - my grand children will inherit my trucks (in 20+ years, I hope).
After a few bends and flares get made in that stuff, what's the chance that- - - -just maybe- - - - -a slightly weak spot in a weld might be stressed by a bending tool or a flaring operation? "Free" could get terribly expensive in that case.
“ my grand children will inherit my trucks (in 20+ years, I hope).”
Tim, I mean Granpa - I cant wait. Thank you for putting me in your will. - Tom
1946 GMC Project
"Back-in-the-day Restore"
ODSS Lawman
ODSS Lawman
Dang Tom, you beat me to it.
Wait, Grandpa Tim has several trucks.......
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
I am down to two 1954 3100 trucks: one for my Granddaughter and one for my Grandson.
No Joke: they will be part of their inheritance, with a maintenance/repair trust fund.
I cried when I gave away the beautiful, fully-restored, 54/55 GMC 350 COE to my young friend who did my restoration painting in NY.
Two rules for the COE - it stays in his family, and, I get to drive it when I visit them in NY.
Moderator: no offense will be taken if these last three posts are deleted, or moved to the Greasy Spoon..
