1 members (J Lucas),
102
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | I removed the 10/24 nuts on the backside of the gauges. Those nuts are a big pain to remove. So I went Ace hardware bought some aluminum threaded inch long spacers.Brought them home put them in the lathe and put a knurled end on them. They turned out nice. | | | | | Joined: Feb 2016 Posts: 1,995 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,995 | I like that idea, good job.
| | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | I’d show you a picture, but I don’t how to you post a picture.😪 I can make more if people are interested!
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | My local Ace & True Value hardware stores in NY and NC had them : 10-24 knurled thumb nut | | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | Mine didn’t. That’s why I had to make them.
| | | | | Joined: Mar 2010 Posts: 10,308 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,308 | I use Ace Hardware knurled brass nuts.
| | | | | Joined: Nov 2018 Posts: 122 'Bolter | | 'Bolter Joined: Nov 2018 Posts: 122 |
My local Ace Hardware (Elizabeth City) closed a while back, Fastenal didn't carry them, so I ordered my knurled brass thumb nuts online from "albanycountyfasteners.com". On my '51-3100 they are 10-32, not 10-24. They work much better than the original nuts.
Charlie
'51 3100 5-Window (Restomod in progress)
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | What size are they on a 1950-3100?
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** My 52 Chevy 3100 & 53 Suburban are also 10/32 thread. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 |
