I started cleaning up the motor to get it ready, and need help identifying what I have. The HEAD Number is: 3835913. On the boss beside the distributor is stamped: KBA733764. I know this is a replacement engine along about 1993, but need to identify it so I can get parts. The flywheel also has 9 bolts to hold the pressure plate on. What do I have? Thanks!
This is in a 1947 3600.....
