Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (TrknGMC, Ed Atkisson, 1 invisible), 58 guests, and 3 robots.
Topics128,010
Posts1,055,299
Members48,419
#1302667 03/11/2019 8:29 PM
I started cleaning up the motor to get it ready, and need help identifying what I have. The HEAD Number is: 3835913. On the boss beside the distributor is stamped: KBA733764. I know this is a replacement engine along about 1993, but need to identify it so I can get parts. The flywheel also has 9 bolts to hold the pressure plate on. What do I have? Thanks!
This is in a 1947 3600.....
Just posted the engine serial number info to your question about the clutch... then saw this post. Anyway, the first three digits of the engine serial number that you see stamped on the pad by the distributor decodes it (the lower end) to a '52 Series 3100 216ci Truck Engine. See: Early Chevy Engine Serial Number ID. The head casting number IDs that as a '54-55 235 truck head. Interesting combination! See: Early Chevy Block & Head Casting Numbers.
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
