1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#1300409 02/24/2019 3:41 PM
I went yesterday and picked up a Coats 40-40a tire machine to add to the shop. I have been looking for one for some time now, but it seemed they were made of gold by the price they were wanting. I happened upon one yesterday that was within a short drive and picked it up. I am excited that I will once again be able to take care of my own tire swaps. A buddy of mine had a 10-10 years ago which is the machine I learned on, but this one is definitely a step up.
Larry
Larry1974 #1300437 02/24/2019 9:28 PM
I spent a lot of time on a similar machine. These days, it's one of those uprights that clamp the rim, etc.
Nice find!
Larry1974 #1300443 02/24/2019 9:58 PM
Cut my teeth on the 10-10 then the company bought 20-20 machines and sold all the 10-10s. The 40-40 came out just after I left the business. Now, like Mark said, they are all stand up machines.
Larry1974 #1301752 03/05/2019 2:48 AM
We picked up a barely used 30-30 machine from a motorcycle shop that went to a "touchless" machine for fancy wheels. Gave $150 for it and stuck it in a corner as I figured it wouldn't be used much. I was wrong. The guys have made up all sorts of custom wheel mounts ranging from go-kart to really big fork lift wheels. The air tube for blowing tires out to the rim has died and the extended center post and bead breaker arm are way over taxed on some wheels but it just keeps chugging along.
Evan
Larry1974 #1302411 03/10/2019 1:51 AM
The "Cheetah" portable inflator tank is the best invention since a pocket on a shirt! Just charge it up with compressed air, aim the flattened pipe at the tire bead, and open the ball valve- - - -just be sure to wear your earmuffs. That thing is LOUD! Sure beats using a big squirt of starting fluid and a match to seat the beads on big truck tires!
Larry1974 #1302416 03/10/2019 2:06 AM
Moderator
Moderator
2 Offline
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Moderated by  MNSmith
