4 members (68ironhead, Shade Baby, Joe H, baldeagle), 93 guests, and 5 robots.
Topics128,014
Posts1,055,329
Members48,419
#1302312 03/09/2019 1:34 PM
Just wondering if anyone has used this product Evans engine coolant. I overheard some people at a car show talking about it, seems like an overpriced Very expensive ( $40.00 a gallon) gimic to me. Anybody have any thoughts on this? I've always used 50/50 regular anti freeze It doesn't get that cold down here in South Louisiana, never had any problems with it. Just kind of wondering what it is that makes younger people think this stuff is the greatest thing since sliced bread? I think it is just a marketing thing, the latest greatest whatever has to be better.
Tell me what you think. headscratch
Tommy
59 apache 1/2t
261 short stepside
Tommy #1302330 03/09/2019 4:27 PM
I bought 5 gallons about 20 years ago, when I had more money than time (to consider the implications). The containers are unopened in my garage. I’ll give them away, if you pick them up at my house/garage in NC.
https://greengarageblog.org/17-waterless-coolant-pros-and-cons
https://www.evanscoolant.com/how-it-works/about-waterless-coolant/
Tommy #1302335 03/09/2019 5:01 PM
I thought about getting it but the only advantage I can see is it does not have water so if it overheats it will not boil over. Since I have installed my new radiator I have no overheating problems just the opposite it does not get hot enough especially in cooler weather.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Tommy #1302339 03/09/2019 5:38 PM
Yep- - - -it's a gimmick. Propylene Glycol was also sold under the brand name "Safety Freeze" at a LOT lower price than that stuff. P.T. Barnum would be proud of the sales pitch they are using to reel in the suckers!
Peak sells propylene glycol under the brand name "Sierra"- - - - -but it's still a "concentrate" that needs to be diluted with water to function properly. It's on Ebay right now for $26.99 a gallon- - - -plus $10.00 shipping.
Tommy #1302340 03/09/2019 6:01 PM
What Jerry said.
Propylene gylcol is slightly less toxic than Ethylene glycol. But unless you dilute both with water, they don't perform well as a coolant. In concentrated form, they don't transfer heat nearly as well as either 50/50 solution or plain water. As far as coolant efficiency, water is about the best you can get, The problem with plain water is that it's VERY hard to pump below about 32F. wink
Tommy #1302342 03/09/2019 6:08 PM
Straight antifreeze- - - - -either ethylene or propylene based, starts getting "slushy" at around 19 degrees ABOVE zero. A 70% concentration of ethylene glycol (30% water) freezes at -68 degrees F. A 50/50 mix goes to -37 F. If it ever gets that cold in Tennessee, I'm going to catch the next plane leaving for Ecuador!
Tommy #1302347 03/09/2019 7:00 PM
Insomniac
Insomniac
Propylene gylcol is in the stuff you drink when preparing for a colonoscopy. big_eek
Good for a radiator flush?
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Tommy #1302362 03/09/2019 8:33 PM
2 Offline
do not drink propylene glycol, it is NOT the chemical you are thinking of.
i was gonna be a chemical engineer before i switched to electrical engineering, keeping all these chemicals straight can get difficult, probably why i switched to EE,
only one of theses related glycols can be "drank" the other three will put you in the hospital with varying prognosis depending on how much you have and how quickly you absorbed it.
-s
Polyethylene glycol:
This is the active chemical in a mixture of other things to prep. for colonoscopies.
PEG is the basis of a number of laxatives (e. g. macrogol-containing products such as Movicol and polyethylene glycol 3350, or SoftLax, MiraLAX, or GlycoLax). Whole bowel irrigation with polyethylene glycol and added electrolytes is used for bowel preparation before surgery or colonoscopy
Polypropylene glycol:
Do Not Drink, you will suffer accute toxicity.
used as a food additive, it is a colorless liquid that is odorless or has a mild sweet odor. May float or sink in water depending on chain length.
Propylene glycol:
Do Not Drink, you will suffer accute toxicity and kidney failure.
used as an organic solvent and diluent in pharmaceuticals and many other industrial applications.
Propylene glycol is used as a solvent for intravenous, oral, and topical pharmaceutical preparations It is generally considered safe. However in large doses it can be toxic, especially if given over a short period of time.
Ethylene Glycol (traditional anti-freese):
colorless, odorless, viscous dihydroxy alcohol. It has a sweet taste, but is poisonous if ingested. Ethylene glycol is the most important glycol commercially available and is manufactured on a large scale in the United States. It is used as an antifreeze and coolant, in hydraulic fluids, and in the manufacture of low-freezing dynamites and resins.
Tommy #1302376 03/09/2019 10:30 PM
Insomniac
Insomniac
Thanks. Good thing I didn't go into the medical profession...
Gord 🇨🇦
Tommy #1302383 03/09/2019 11:21 PM
Why? You'd only have two models to work on, and those haven't changed in thousands of years- - - -you get paid whether you succeed or not- - - - -and you can bury your mistakes. Mechanics should charge more than doctors for their services!
Tommy #1302395 03/10/2019 12:15 AM
Insomniac
Insomniac
Well, my handwriting is legible so that rules me out.
As for coolant, just use Prestone. They* say you can in use it in any vehicle and you can mix it with any existing coolant (any color) without harm.
*according to Prestone's advertising.
Gord 🇨🇦
