11 members (Bill Hanlon, MickeyP, 68ironhead, Greg_H, Otto Skorzeny, tclederman, Shade Baby, 3B, Charles in CA, 32Fordpuchoptop, JW51), 84 guests, and 1 robot.
Topics128,050
Posts1,055,648
#1302226 03/08/2019 6:13 PM
I have a spare Sm420 that I would like to play with, learn some and maybe rebuilt if required/desired. Has a brake which I will remove and replace with a back plate suitable for my stock drive shaft. 283 engine.
Can someone ID this transmission?
What back plate am I looking for? What am I asking/looking for?
Are the input and output shaft splines correct or do I need to fuss with shafts as well, which might be the deal closer.
Thanks for any help to get me started.
~ HB
1962 Chevrolet C10
1962 Suburban
Hambone #1302239 03/08/2019 7:35 PM
Your trans was casted on April 6th 1962 and was setup for big truck with handbrake/drum mounted on the transmission. You only need to remove the rear bearing cover and replace it with the standard duty cover from 1948 on up to 1966 like this one attached part number 591701, Type in that part number in ebay and one is for sale now.
Input and output shafts are compatible and correct, in actuality, once the drum is removed it (your existing bearing cover)doesn't even need to be removed, it will accept the standard driveshaft yoke but it would clean it up nicely otherwise.
Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Hambone #1302251 03/08/2019 9:41 PM
Good info. Thanks for part number.
~ HB
1962 Chevrolet C10
1962 Suburban
Hambone #1302254 03/08/2019 9:55 PM
Am I missing something? Does picture three in the original post show a different output shaft?
1953 Canadian GMC 9314 w/ (factory) Chevy 235
Hambone #1302257 03/08/2019 10:13 PM
No the parking brake drum is removed only, exposing the rear bearing cover
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Hambone #1302270 03/09/2019 12:00 AM
Is there any reason to remove the parking brake drum system? I have done it, but after fighting the cable system on my 52, I am considering putting one on so as to not have to deal with the misery of the cables
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Hambone #1302285 03/09/2019 1:45 AM
No, actually it is a better parking brake system IMHO, designed for heavy vehicles fully laden.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Hambone #1302305 03/09/2019 11:47 AM
I have been told that there is damage to the brake bracket in my pictured transmission. I believe in pix 3, on the left side, the arm (?) that holds something against the drum is busted. I have been told this renders the brake/back plate useless and on no value to anyone.
~ HB
1962 Chevrolet C10
1962 Suburban
Hambone #1302319 03/09/2019 2:23 PM
Yes, I see that now, sorry for not catching that.
Still if you wanted to save a few bucks and do a little work, you could cut the existing bracket in these locations and use it after replacing the rear seal of course.
Steve
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Hambone #1302408 03/10/2019 1:27 AM
Yes, the band brake support shank is broken off of your Retainer Plate. The only thing that plate is good for now is for a 1/2 ton truck that doesn't use a propeller shaft parking brake system...they uses cables to the rear axle drums like a car.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
