3 members (1955 1 Series, Jay R, Otto Skorzeny), 164 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#130220 11/19/2002 2:09 PM
I am installing a 350 in my 50 Chevy. I am rebuilding it and have the option to change the cam. Any suggestions? I will use the truck mostly for in and around town. I plan to put very few long distance miles on it. Occasionally I will take it out on the hiway. I was thinking of getting the Edelbrock EDL-7102 with a 234 Int and 244 exh and match it to their performance manifold.
#130221 11/19/2002 6:41 PM
Need to know the rest of the setup to suggest a good cam.
What is your compression ratio?
What size carb in CFM?
Single or dual-plane intake?
What tranny? Stall speed?
What rear gear ratio?
Desired powerband in RPM?
Smooth or Choppy idle?
Vehicle weight?
A 234/244 at .050" is gonna have a fairly choppy idle at about 800-1,000 RPM. You'd need at least 9:1 compresson to get good performance at lower RPMs.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#130222 11/19/2002 10:49 PM
smile howziit guys!
JMO, rpm cam would not work well for you. 1500-6500rpm range, not as much HP/TQ in low and midrange as other similar cams, comes on like gangbusters in high-end. needs high-perf heads,gears, headers, converter, not recommended for heavy vehicles.
it would be the worst engine mistake you could make.
my friend has a '91 half-ton, with ZZ4 short-block, 8.9cr, edelbrock rpm heads/cam/intake/600carb, gears, headers, exhaust. from the way this heavy truck moves, i knows he's very disappointed.
with stock heads, low compression ratio,edelbrock PERFORMER intake, 600 carb or OEM QuadraJet, you'd probably like a "4 by 4" cam, 600-4600rpm range, 206-214*D(250-258*D)/.432-.453Lift/111*LSA.
but i would not recommend the performer cam, either. choose any other manufacturer, except that one.
Myron
1956 chevy 3100 stepside, Pro-Street stance, mild 454 BBC/350/9"/13" M/T'S, daily driver, aka THE PINK LADY
1957 Bel-Air coupe, 500 HP blown sbc in progress, aka LANI
#130223 11/19/2002 11:13 PM
I've heard really good things about the Comp Cams X-Treme energy series. They build cylinder pressure in low CR engines to make good grunt and mid-range. Still need the engine specs to make a really good choice.
chip
#130224 11/20/2002 2:42 PM
Heaven,
Actually, this boy has become more educated. I found out that if I go higher than a 210 duration I will need to change torque converters in my tranny and possibly redo the heads. So, I am stuck (maybe a blessing) using a 210. What type intake manifold, carb, and exhaust pipes should I consider? Thanks!
#130225 11/20/2002 7:58 PM
smile howziit Richie!
we ALL gain knowledge, from almost every topic we read into! smile
JMO, go with the tried and true: from the stock, rebuilt 350, with OEM QJet, you could add:
OEM HEI distributor
OEM thermal clutch fan
Crane adjustable vacuum diaphragm kit,w/springs$23)
1 5/8" headers(standard size)
edelbrock PERFORMER, or WEIAND#8007 intake
small cam
heyyy, that's all you might need!
Myron
