| | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 61 Member | | Member Joined: May 2001 Posts: 61 | I am installing a 350 in my 50 Chevy. I am rebuilding it and have the option to change the cam. Any suggestions? I will use the truck mostly for in and around town. I plan to put very few long distance miles on it. Occasionally I will take it out on the hiway. I was thinking of getting the Edelbrock EDL-7102 with a 234 Int and 244 exh and match it to their performance manifold. | | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Need to know the rest of the setup to suggest a good cam. What is your compression ratio? What size carb in CFM? Single or dual-plane intake? What tranny? Stall speed? What rear gear ratio? Desired powerband in RPM? Smooth or Choppy idle? Vehicle weight?
A 234/244 at .050" is gonna have a fairly choppy idle at about 800-1,000 RPM. You'd need at least 9:1 compresson to get good performance at lower RPMs.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
| | | | | Joined: Sep 2002 Posts: 72 Member | | Member Joined: Sep 2002 Posts: 72 |  howziit guys! JMO, rpm cam would not work well for you. 1500-6500rpm range, not as much HP/TQ in low and midrange as other similar cams, comes on like gangbusters in high-end. needs high-perf heads,gears, headers, converter, not recommended for heavy vehicles. it would be the worst engine mistake you could make. my friend has a '91 half-ton, with ZZ4 short-block, 8.9cr, edelbrock rpm heads/cam/intake/600carb, gears, headers, exhaust. from the way this heavy truck moves, i knows he's very disappointed. with stock heads, low compression ratio,edelbrock PERFORMER intake, 600 carb or OEM QuadraJet, you'd probably like a "4 by 4" cam, 600-4600rpm range, 206-214*D(250-258*D)/.432-.453Lift/111*LSA. but i would not recommend the performer cam, either. choose any other manufacturer, except that one.
Myron
1956 chevy 3100 stepside, Pro-Street stance, mild 454 BBC/350/9"/13" M/T'S, daily driver, aka THE PINK LADY
1957 Bel-Air coupe, 500 HP blown sbc in progress, aka LANI
| | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | I've heard really good things about the Comp Cams X-Treme energy series. They build cylinder pressure in low CR engines to make good grunt and mid-range. Still need the engine specs to make a really good choice.
chip
| | | | | Joined: May 2001 Posts: 61 Member | | Member Joined: May 2001 Posts: 61 | Heaven,
Actually, this boy has become more educated. I found out that if I go higher than a 210 duration I will need to change torque converters in my tranny and possibly redo the heads. So, I am stuck (maybe a blessing) using a 210. What type intake manifold, carb, and exhaust pipes should I consider? Thanks! | | | | | Joined: Sep 2002 Posts: 72 Member | | Member Joined: Sep 2002 Posts: 72 |  howziit Richie! we ALL gain knowledge, from almost every topic we read into! JMO, go with the tried and true: from the stock, rebuilt 350, with OEM QJet, you could add: OEM HEI distributor OEM thermal clutch fan Crane adjustable vacuum diaphragm kit,w/springs$23) 1 5/8" headers(standard size) edelbrock PERFORMER, or WEIAND#8007 intake small cam heyyy, that's all you might need!
Myron
