Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (KEVINSKI, 68ironhead, 1 invisible), 103 guests, and 4 robots.
Topics128,274
Posts1,058,436
Members48,490
#1301955 03/06/2019 6:34 PM
Still confusion in my feeble mind over tire sizes. I've read thru much of what's here, especially Denny Graham's thread from a couple years ago. I'm wanting to put a radial tire on stock 16 inch rims on my 1947 GMC 1/2 ton. The truck will be an occasional driver with a farm truck vibe. Black side walls. It looks to me like the 215-85r-16 is the way to go.(?) Not planning on using tubes, but I don't know if that's a good decision. I want my truck to look like this...eventually. (not sure who own's this truck but I dig it!)
I suppose my questions are: Will the 215-85r-16 fit on a stock rim? And, Do I need tubes in these?
Just Mark #1301956 03/06/2019 6:41 PM
Just Mark #1301957 03/06/2019 6:50 PM
Not sure. How do I measure em?
Just Mark #1301965 03/06/2019 7:59 PM
If the tire is off the rim, just measure the distance between bead seats. With tires on, it's a little tougher. You'd need a caliper to reach around the tire, again measuring where the bead of the tire seats. The dimension using that method would be slightly larger due to the thickness of the metal, but you should be able to tell the difference between 4.0 or 4.5 inches width.
Just Mark #1301968 03/06/2019 8:18 PM
I've got 3 rims with tires holding the truck up, and one that I bought from someone here with no tire. That one looks to be a 4 incher.
Just Mark #1301982 03/06/2019 10:56 PM
ODSS Lawman
ODSS Lawman
JustMark
I really dig your taste in trucks! The photo in your first post is my truck.
Those tires are now 12 years old! With over 30,000 miles on them.
No tubes, stock rims. I can check the size when I get home.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Just Mark #1301986 03/06/2019 11:30 PM
I think the rims are marked/ stamped with the size on the backside. It should read 16X4.00E or 16X4.50E, or something like that. Might have to scrub the dirt, grease, grime or rust off to see it.
Professional Novice
Just Mark #1302004 03/07/2019 1:16 AM
Thanks Sweet. I've got a couple pictures of your truck on my computer. Great looking truck. Yeah, if you could check the size that'd be great.
Thanks Frank, I'll check the rim tomorrow. I suppose it's possible I have a mismatched set.
Just Mark #1302096 03/07/2019 7:05 PM
And about epoxy. I've read on a couple threads about putting epoxy on the rivet areas to help keep them sealed. What kind of epoxy? Where do I get such epoxy?
Just Mark #1302099 03/07/2019 8:07 PM
Any two part general purpose epoxy will do ya.
Like this:
https://www.homedepot.com/p/Gorilla-7-8-fl-oz-General-Purpose-Epoxy-42001/100670610
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Just Mark #1302100 03/07/2019 8:08 PM
Oh, cool. Thanks.
Frank50 #1302101 03/07/2019 8:09 PM
Nuthin on mine. There's #2 on the inside between the rivets but that's about it.
Just Mark #1302103 03/07/2019 8:11 PM
When you measure your wheels for width a 4.5" rim will actually be about 5.5" outside to outside
A3 indicated built Jan of 1953
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Just Mark #1302106 03/07/2019 8:20 PM
Never had to use anything on wheels when going tubeless. Here is a 53 we did that may be the look you're going after. The tires are 215/85R but may be on 15" wheels---I don't remember but tire OD should be close.
[img]https://i.postimg.cc/c6gp1m6R/Picture-014.jpg[/img]
Evan
Just Mark #1302159 03/08/2019 3:05 AM
I had 4 tubeless radials mounted and only one leaked past the rivets. Epoxy fixed that one. 2,000 miles ans still no leaks. I recommend epoxy on all of them just for good measure.
Just Mark #1302188 03/08/2019 12:49 PM
Evan, That's exactly what I'm looking for. Even the color. Thanks.
Carl, sounds like a good plan to me.
Just Mark #1302232 03/08/2019 6:25 PM
Awesome Grandpa
Awesome Grandpa
I'm also looking for rims / tires for my 1954 3100 and going for the "Farm Truck" look.
That green is a great color!
The previous owner put 15" rims with too wide of tires on it:
The rear tires are P275/60SR15
The front tires are P235/60R15
Considering 16" Wheel Vintiques rims .....but not sure their hub caps will clear the wheel bearing dust covers.
Wheel Vintiques
12 series smoothies
16x6 6x51/2 BKSP 4" 12-660604
https://www.wheelvintiques.com/wheels/truck/smoothie-bare-finish.html
Hub Caps
Chevy Cap for Smoothie (1952)
Going to Portland Swap meet in a few weeks looking for rims ....
wide tires
"Farm Truck"
Just Mark #1302271 03/09/2019 12:01 AM
darthintel cool truck. If you decide to go with a non spare rear fender let me know. I'm looking to by a spare tire set up.
Just Mark #1302279 03/09/2019 1:06 AM
Awesome Grandpa
Awesome Grandpa
I just bought a spare tire carrier on Ebay for $20 - as I want to keep the spare.
My truck had the mounts on the truck, just missing the carrier.
Just Mark #1304247 03/22/2019 8:39 PM
Got my tires on today. They are AT Turos, Whatever that is, 215-85R-16. At first they looked taller than I wanted, but I like em now. They have the farm truck vibe that I wanted.
(I'll post this on the area that I'm posting my progress, figured I'd put it here for the future generations that are always asking the tire question.)
Just Mark #1304249 03/22/2019 8:59 PM
Nice truck . I think the tires and wheels make it.
1946 GMC Project
"Back-in-the-day Restore"
Just Mark #1304250 03/22/2019 9:34 PM
Thanks! I'm really digging this truck. I think it'll be pretty cool once I buff what's left of the paint out and put the bumper etc back on.
Just Mark #1304251 03/22/2019 9:53 PM
Yeah. I like the GMC front clip too. Certainly is something to be proud of. Thanks for your posting about tire sizes too. I will refer to it at a later date.
1946 GMC Project
Just Mark #1307217 04/15/2019 9:18 PM
Awesome Grandpa
Awesome Grandpa
Where are the rims from? I'm looking for 16 x 6 for my 1954 chev 3100.
