Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Hotrod Lincoln, Rich'sToys, Peggy M, 1 invisible), 111 guests, and 5 robots.
Topics128,290
Posts1,058,558
Members48,492
I have seen many 48/53 Trucks with **** factory MII crossmembers. Can anyone give me advice on tricks, specs, measurements or whatever on this install. I have installed Heidt's MII in my 34 **** but would like to save $400 and use a **** one I have. Thanks.
Ron Thompson
51 Chevy 1/2 ton
36 F@rd coupe
65 Riviera
Ron-I've got an article in Truckin' Magazine May 1982 edition which details this install. It may well give you the insight you need to proceed with this project. E-mail me your snail mail address and I'll take a photocopy and send it your way.
[email protected]
Wannabe smile
"Don't expect anything and you'll never be disappointed"
Yeah. Wannabe,
You sent me the same article and as of today I'm wrecking out 77/78 Bobcat for the front and rear end, and anything else I can use. May get the 41 in the garage before winter.
Dennis
No prob, dabond. Ron, your copy is in the mail, as of Tuesday. But you might have already checked your email before you read this.
Wannabe smile
HI RON
I HAVE JUST INSTALED AN M--- 11 FRONT END IN MY 53 3/4 TON AND WOULD RECOMEND YOU INVEST IN A FATMAN FABRICATIONS CROSS MEMBER KIT. IT IS TOP QUALITY AND SAVES LOADS ON BANDAIDS.
YOU CAN HANG ALL THE STOCK M--- 11 STUFF FROM IT.
HOPE THIS HELP'S GOOD LUCK
NICK Mc 53 CHEVY 3/4 TON FIVEWINDOW
THIS AINT NO PRACTISE RUN YOU DON'T
GET A SECOND GO.
